Scale your MySQL Router K8s
This is part of the Charmed MySQL Tutorial. Please refer to this page for more information and the overview of the content.
Adding and Removing units
Please check the explanation of scaling Charmed MySQL K8s operator here.
Add more mysql-router instances
You can add two more units to your deployed MySQL Router application by scaling it to three units using:
juju scale-application mysql-router-k8s 3
You can now watch the scaling process in live using: juju status --watch 1s. It usually takes several minutes for new cluster members to be added. You’ll know that all three nodes are in sync when juju status reports Workload=active and Agent=idle:
tutorial overlord microk8s/localhost 2.9.46 unsupported 22:48:57+01:00
data-integrator active 1 data-integrator stable 13 10.152.183.142 no
mysql-k8s 8.0.34-0ubuntu0.22.04.1 active 1 mysql-k8s 8.0/edge 109 10.152.183.68 no
mysql-router-k8s 8.0.34-0ubuntu0.22.04.1 active 3 mysql-router-k8s 8.0/edge 68 10.152.183.52 no
data-integrator/0* active idle 10.1.12.3
mysql-k8s/0* active idle 10.1.12.36 Primary
mysql-router-k8s/0* active idle 10.1.12.14
mysql-router-k8s/1 active idle 10.1.12.32
mysql-router-k8s/2 active idle 10.1.12.31
The same way you can scale Charmed MySQL:
juju scale-application mysql-k8s 3
Make sure all units are active (using juju status):
mysql-k8s 8.0.34-0ubuntu0.22.04.1 active 3 mysql-k8s 8.0/edge 109 10.152.183.68 no
mysql-k8s/1 active idle 10.1.12.34
mysql-k8s/2 active idle 10.1.12.43
Remove extra members
Removing a unit from the application, scales the replicas down.
juju scale-application mysql-router-k8s 2
juju scale-application mysql-k8s 2
You’ll know that the replica was successfully removed when juju status --watch 1s reports:
mysql-k8s 8.0.34-0ubuntu0.22.04.1 active 2 mysql-k8s 8.0/edge 109 10.152.183.68 no
mysql-router-k8s 8.0.34-0ubuntu0.22.04.1 active 2 mysql-router-k8s 8.0/edge 68 10.152.183.52 no
