Adding metrics to a charm is simple and straightforward with the reactive framework. For a general overview of metrics see Application metrics.
Add layer:metrics
Add layer:metrics to the charm’s layer.yaml. This layer provides the collect-metrics hook, and allows metric collection to be defined completely by metrics.yaml.
Add metrics.yaml
Declare the metrics to be collected in your charm’s metrics.yaml. Example:
metrics:
users:
type: gauge
description: Number of users
tokens:
type: gauge
description: Number of active tokens
Metric types
Only type: gauge fully supports operational use-cases. Other types are experimental.
`type: gauge`
Gauge metrics are a snapshot value reading at a point in time, as a positive decimal number.
`type: absolute`
Absolute metrics track the quantity since the last measurement, as a positive decimal number. Future releases of Juju will track the cumulative aggregate of absolutes, providing a more useful indicator to operators.
Built-in metric `juju-units`
There is also a built-in metric, which has no type or description, named juju-units. When declared, this metric sends a “1” for each unit.
Metric commands
When charming with layer:metrics, add a command: attribute to each metric in metrics.yaml, containing a command line that measures the value when executed. layer:metrics will then execute this command in the collect-metrics hook for you automatically. Continuing with the example above:
metrics:
users:
type: gauge
command: scripts/count_users.py
tokens:
type: gauge
command: scripts/count_tokens.py
Commands can use any script or executable in your charm or installed elsewhere on the workload. The current working directory for this command will be the charm directory (charmhelpers.core.hookenv.charm_dir). The command must write only the metric value to standard output, and terminate with exit code 0 in order for the measurement to be to be counted valid.
Continuing with the metrics example above, a charm that relates to a PostgreSQL database probably stores its “users” and “tokens” in database tables. These can be counted with a simple SQL query. scripts/count_users.py in such a charm might read as:
#!/usr/bin/env python3
# Python packages will have been installed by the charm.
import configparser
import psycopg2
if __name__ == '__main__':
# Read the application's configuration file, which will have been written
# by the charm's relation hooks.
with open('/opt/sso-auth/config.ini') as f:
config_str = f.read()
config = configparser.ConfigParser(strict=False)
config.read_string(config_str)
# Build a database connection string from configuration.
dbname = config['database']['NAME']
user = config['database']['USER']
password = config['database']['PASSWD']
hostport = config['database']['HOST']
host, port = hostport.split(':')
conn_str = 'dbname=%s user=%s password=%s host=%s port=%s' % (
dbname, user, password, host, port)
conn = psycopg2.connect(conn_str)
try:
cur = conn.cursor()
try:
# For sake of example, let's say we don't want to include the
# default admin user account in the count.
cur.execute("SELECT COUNT(1) FROM users WHERE name != 'admin';")
row, = cur.fetchone()
print(row) # Print the measurement to standard output, for Juju
finally:
cur.close()
finally:
conn.close()
Note that this command will not have access to the normal lifecycle hook environment. Refer to the collect-metrics documentation for more information.
