As a Juju administrator, you may find yourself wanting to know more about the resources that an application in your model consumes and provides, such as:
- Storage GiB used
- Number of user accounts
- Number of recently active users
- Active database connections
Juju collects application metrics at a cadence appropriate for taking a model-level assessment of application utilisation and capacity planning.
Using metrics
View the most recent measurements from workloads that collect them with the metrics
command. View measurements for at the model level with:
juju metrics --all
Measurements from all metered workloads in the model are displayed:
UNIT TIMESTAMP METRIC VALUE
webapp/0 2016-09-19T22:17:57Z requests 11903
webapp/1 2016-09-19T22:17:52Z requests 13719
ceph-mon/0 2016-09-19T22:15:36Z gb-usage 5.2711902345
auth-sso/0 2016-09-19T22:14:29Z users 28
auth-sso/0 2016-09-19T22:14:31Z tokens 6
View measurements at the unit level:
juju metrics webapp/0
Only webapp/0
measurements are shown:
webapp/0 2016-09-19T22:17:57Z requests 13719
View measurements at the application level:
juju metrics sso-auth
Measurements from all matching units are shown:
Machine readable formats are also supported:
juju metrics auth-sso --format yaml
Producing output ideal for integrating with data analysis and automation systems:
- unit: auth-sso/0
timestamp: 2016-09-29T21:55:54.182Z
metric: users
value: "30"
- unit: auth-sso/0
timestamp: 2016-09-29T21:55:53.319Z
metric: tokens
value: "7"
What does a charm measure?
The measurements collected by a charm are declared in its metrics.yaml
. For example:
metrics:
users:
type: gauge
description: Number of users
tokens:
type: gauge
description: Number of active tokens
For a more detailed explanation of metrics.yaml
, refer to the Metric types section in the developer documentation.
What else are metrics used for?
Measurements collected by Juju are also sent to Canonical, where they are aggregated across all deployments of the charm for analytics. This information may be used to improve Juju, and may be shared with the charm developer to better support and improve the charm. Canonical respects the privacy of its users and will not disclose the specific usage of individual users without prior consent. You may opt-out of anonymous analytics at any time by setting the model configuration parameter transmit-vendor-metrics=false
