Hi,
We’re writing some documentation on upgrading a charm from a pod-spec version to the sidecar version. Unfortunately the pod-spec version was using StoredState without use_juju_for_storage=True, and the DB relation’s info is stored there, so when you upgrade currently the charm can’t find that data in StoredState (this is another good cautionary tale as to why using StoredState can catch you out). One option here is to break the relation and recreate it, but I’d like to know if it’s possible to simply trigger the relevant event manually.
Here’s the relevant part of show-unit (local deployment, so passwords are okay to show here):
discourse-k8s/0:
opened-ports: []
charm: ch:amd64/focal/discourse-k8s-8
leader: true
life: alive
relation-info:
- relation-id: 1
endpoint: db
related-endpoint: db-admin
application-data:
allowed-subnets: 10.152.183.161/32
allowed-units: discourse-k8s/0
database: discourse-k8s
host: 10.152.183.105
master: dbname=discourse-k8s fallback_application_name=discourse-k8s host=10.152.183.105
password=ytqjVHPrdNPwPYH6zBpj4mJmf754w6hxRwmbPrpy port=5432 user=discourse-k8s
password: ytqjVHPrdNPwPYH6zBpj4mJmf754w6hxRwmbPrpy
port: "5432"
standbys: dbname=discourse-k8s fallback_application_name=discourse-k8s host=10.152.183.206
state: master
user: discourse-k8s
version: "12"
related-units:
postgresql-k8s/0:
in-scope: true
data:
port: "5432"
state: master
user: discourse-k8s
version: "12"
I’ve been trying the following, based on some code I’ve seen in another charm:
juju run --unit discourse-k8s/0 "JUJU_RELATION=db JUJU_RELATION_ID=1 JUJU_DISPATCH_PATH=db-relation-joined timeout 1200 ./dispatch"
If I tried this without JUJU_RELATION or JUJU_RELATION_ID I get an error in juju debug-log, but if I include them both I don’t see any relevant output in debug-log and the event doesn’t seem to be triggered.
Does anyone know what I’m missing here?
Thanks, Tom
