From Zero to Hero: Write your first Kubernetes charm > Make your charm configurable
See previous: Create a minimal Kubernetes charm
This document is part of a series, and we recommend you follow it in sequence. However, you can also jump straight in by checking out the code from the previous branches:
git clone https://github.com/canonical/juju-sdk-tutorial-k8s.git
cd juju-sdk-tutorial-k8s
git checkout 01_create_minimal_charm
git checkout -b 02_make_your_charm_configurable
A charm might have a specific configuration that the charm developer might want to expose to the charm user so that the latter can change specific settings during runtime.
As a charm developer, it is thus important to know how to make your charm configurable.
This can be done by defining a charm configuration in a file called config.yaml
and then adding configuration event handlers (‘hooks’) in the src/charm.py
file.
In this part of the tutorial you will update your charm to make it possible for a charm user to change the port on which the workload application is available.
Read more: How to make your charm configurable
Contents:
- Define the configuration options
- Define the configuration event handlers
- Validate your charm
- Review the final code
To begin with, let’s define the options that will be available for configuration.
In the charmcraft.yaml
file you created earlier, define a configuration option, as below. The name of your configurable option is going to be server-port
. The default
value is 8000
– this is the value you’re trying to allow a charm user to configure.
config:
options:
server-port:
default: 8000
description: Default port on which FastAPI is available
type: int
Read more:
options
Open your src/charm.py
file.
In the __init__
function, add an observer for the config_changed
event and pair it with an _on_config_changed
handler:
framework.observe(self.on.config_changed, self._on_config_changed)
Read more: Event ‘config-changed’
Now, define the handler, as below. First, read the self.config
attribute to get the new value of the setting. Then, validate that this value is allowed (or block the charm otherwise). Next, let’s log the value to the logger. Finally, since configuring something like a port affects the way we call our workload application, we also need to update our pebble configuration, which we will do via a newly created method _update_layer_and_restart
that we will define shortly.
def _on_config_changed(self, event):
port = self.config["server-port"] # see config.yaml
if port == 22:
self.unit.status = ops.BlockedStatus("invalid port number, 22 is reserved for SSH")
return
logger.debug("New application port is requested: %s", port)
self._update_layer_and_restart(None)
A charm does not know which configuration option has been changed. Thus, make sure to validate all the values. This is especially important since multiple values can be changed in one call.
In the __init__
function, add a new attribute to define a container object for your workload:
# see 'containers' in charmcraft.yaml
self.container = self.unit.get_container("demo-server")
Create a new method, as below. This method will get the current Pebble layer configuration and compare the new and the existing service definitions – if they differ, it will update the layer and restart the service.
def _update_layer_and_restart(self, event) -> None:
"""Define and start a workload using the Pebble API.
You'll need to specify the right entrypoint and environment
configuration for your specific workload. Tip: you can see the
standard entrypoint of an existing container using docker inspect
Learn more about Pebble layers at https://github.com/canonical/pebble
# Learn more about statuses in the SDK docs:
# https://juju.is/docs/sdk/constructs#heading--statuses
self.unit.status = ops.MaintenanceStatus("Assembling Pebble layers")
new_layer = self._pebble_layer.to_dict()
try:
# Get the current pebble layer config
services = self.container.get_plan().to_dict().get("services", {})
if services != new_layer["services"]:
# Changes were made, add the new layer
self.container.add_layer("fastapi_demo", self._pebble_layer, combine=True)
logger.info("Added updated layer 'fastapi_demo' to Pebble plan")
self.container.restart(self.pebble_service_name)
logger.info(f"Restarted '{self.pebble_service_name}' service")
self.unit.status = ops.ActiveStatus()
except (ops.pebble.ConnectionError, ops.pebble.APIError):
self.unit.status = ops.WaitingStatus("Waiting for Pebble in workload container")
Now, crucially, update the _pebble_layer
property to make the layer definition dynamic, as shown below. This will replace the static port 8000
with f"--port={self.config['server-port']}"
command = " ".join(
"uvicorn",
"api_demo_server.app:app",
"--host=0.0.0.0",
f"--port={self.config['server-port']}",
As you may have noticed, the new _update_layer_and_restart
method looks like a more advanced variant of the existing _on_demo_server_pebble_ready
method. Remove the _on_demo_server_pebble_ready
method and, in the __init__
method, bind the new _update_layer_and_restart
method in the event observer instead. The final __init__
method should look as below:
def __init__(self, framework):
super().__init__(framework)
self.pebble_service_name = "fastapi-service"
self.container = self.unit.get_container("demo-server") # see 'containers' in charmcraft.yaml
framework.observe(self.on.demo_server_pebble_ready, self._update_layer_and_restart)
Validate your charm
First, repack and refresh your charm:
charmcraft pack
juju refresh \
--path="./demo-api-charm_ubuntu-22.04-amd64.charm" \
demo-api-charm --force-units --resource \
demo-server-image=ghcr.io/canonical/api_demo_server:1.0.1
Now, check the available configuration options:
juju config demo-api-charm
Our newly defined server-port
option is there. Let’s try to configure it to something else, e.g., 5000
juju config demo-api-charm server-port=5000
Now, let’s validate that the app is actually running and reachable on the new port by sending the HTTP request below, where 10.1.157.74
is the IP of our pod and 5000
is the new application port:
curl 10.1.157.74:5000/version
You should see JSON string with the version of the application: {"version":"1.0.1"}
Let’s also verify that our invalid port number check works by setting the port to 22
and then running juju status
juju config demo-api-charm server-port=22
juju status
As expected, the application is indeed in the blocked
state:
charm-model tutorial-controller microk8s/localhost 3.0.0 unsupported 18:19:24+01:00
demo-api-charm blocked 1 demo-api-charm 2 10.152.183.215 no invalid port number, 22 is reserved for SSH
demo-api-charm/0* blocked idle 10.1.157.74 invalid port number, 22 is reserved for SSH
Congratulations, you now know how to make your charm configurable!
For the full code see: 02_make_your_charm_configurable
For a comparative view of the code before and after this doc see: Comparison
See next: Expose the version of the application behind your charm
Contributors: @beliaev-maksim
