MAAS Site Manager K8s docs - Installation
MAAS Site Manager Installation
The recommended way of deploying MAAS Site Manager K8s is via Terraform. Below we outline the steps to do so.
Deploy charms via Terraform
MAAS Site Manager has a Terraform plan that you may use to easily deploy all charms (except for the COS Lite stack). If you instead wish to deploy the charms manually, skip this section and continue with the Manual Deployment Tutorial.
If you wish to use the Terraform plan, first download the files to a directory:
mkdir msm-deployment
cd msm-deployment
curl https://git.launchpad.net/maas-site-manager/plain/deployment/terraform/main.tf -O
curl https://git.launchpad.net/maas-site-manager/plain/deployment/terraform/provider.tf -O
curl https://git.launchpad.net/maas-site-manager/plain/deployment/terraform/temporal.tf -O
curl https://git.launchpad.net/maas-site-manager/plain/deployment/terraform/variables.tf -O
Next, set some environment variables so that Terraform can talk to the Juju controller:
export CONTROLLER=$(juju whoami | yq .Controller)
export JUJU_CONTROLLER_ADDRESSES=$(juju show-controller | yq .$CONTROLLER.details.api-endpoints | yq -r '. | join(",")')
export JUJU_USERNAME="$(cat ~/.local/share/juju/accounts.yaml | yq .controllers.$CONTROLLER.user|tr -d '"')"
export JUJU_PASSWORD="$(cat ~/.local/share/juju/accounts.yaml | yq .controllers.$CONTROLLER.password|tr -d '"')"
export JUJU_CA_CERT="$(juju show-controller $(echo $CONTROLLER|tr -d '"') | yq '.[$CONTROLLER]'.details.\"ca-cert\"|tr -d '"'|sed 's/\\n/\n/g')"
Deploy Object Storage and S3 Integrator
MAAS Site Manager requires an object storage service, such as Ceph. For a development environment, microceph is sufficient. Note that microceph’s rgw service uses port 80 by default. If you are installing microceph in the same VM as MAAS Site Manager, change the rgw port to something else (we use 8080 below). Throughout the microceph setup tutorial, take note of the access key and secret key created.
Configure the deployment
The MAAS Site Manager Terraform plan can take various input variables. Make sure to create a file called terraform.tfvars inside the msm-deployment directory with the required entries below, or see the sample file.
# Use the IP address from `sudo microceph status` and the port specified with `sudo microceph enable rgw`
s3_endpoint = "http://10.207.11.185:8080"
s3_access_key = "my_access_key"
s3_secret_key = "my_secret_key"
s3_bucket = "my_s3_bucket"
The Terraform plan will deploy MAAS Site Manager, Postgresql, Traefik, S3 Integrator, and the Temporal charms. You may instruct the Terraform plan to skip deploying some of these charms by specifying a Juju offer URL in the terraform.tfvars file. See the variables.tf file you downloaded earlier for which offers you may specify.
As the Terraform plan does not deploy the COS Lite stack, you may do so yourself and specify offer URLs for the following endpoints in terraform.tfvars:
  • logging-consumer:loki_push_api
  • metrics-endpoint:prometheus_scrape
  • grafana-dashboard:grafana_dashboard
Deploy the charms
Once you’ve configured your deployment, run the Terraform plan:
terraform init
terraform apply -auto-approve
Finally, create a MAAS Site Manager admin account and login at http://<INGRESS_IP>/msm-maas-site-manager-k8s
# Create admin account
juju run -m msm maas-site-manager-k8s/0 create-admin username=admin password=admin email=admin@example.com
