Litmus Auth Charm (part of Charmed Chaos Engineering)
litmus-auth-k8s is a charm that, in conjunction with the litmus-chaoscenter-k8s charm, the litmus-backend-k8s charm, and mongodb-k8s charm deploys and operates the control plane of LitmusChaos, an open source platform used for chaos testing.
A litmus-auth-k8s application is responsible for authenticating and authorising requests received by litmus-chaoscenter-k8s.
Important! This charm is meant to work in conjunction with its counterparts. This documentation only contains charm-specific, and as such relatively low-level documentation. For the solution-level documentation, look at the solution-level Charmed Chaos Engineering docs.
Project and community
Charmed Litmus is an open source project that warmly welcomes community projects, contributions, suggestions, fixes and constructive feedback.
