Litmus Chaoscenter Charm (part of Charmed Chaos Engineering)
litmus-chaoscenter-k8s is a charm that, in conjunction with the litmus-auth-k8s charm, the litmus-backend-k8s charm, and mongodb-k8s charm deploys and operates the control plane of LitmusChaos, an open source platform used for chaos testing.
A litmus-chaoscenter-k8s application provides the central user interface for the Litmus solution. It enables users to create, schedule, and manage chaos experiments. It also serves as a façade API endpoint, routing client requests to the litmus-auth-k8s and litmus-backend-k8s services.
In addition, when integrated with the litmus-infrastructure-k8s charm, it automates the provisioning and management of the Litmus execution-plane infrastructure within a Juju model, which is required to run chaos experiments.
Important! This charm is meant to work in conjunction with its counterparts. This documentation only contains charm-specific, and as such relatively low-level documentation. For the solution-level documentation, look at the solution-level Charmed Chaos Engineering docs.
Project and community
Charmed Litmus is an open source project that warmly welcomes community projects, contributions, suggestions, fixes and constructive feedback.
