Configuration > List of controller configuration keys
See also: Controller, How to manage configuration values for a controller
agent-logfile-max-backups
agent-logfile-max-size
agent-ratelimit-max
agent-ratelimit-rate
allow-model-access
api-port
api-port-open-delay
application-resource-download-limit
audit-log-capture-args
audit-log-exclude-methods
audit-log-max-backups
audit-log-max-size
auditing-enabled
autocert-dns-name
autocert-url
ca-cert
caas-image-repo
caas-operator-image-path
controller-api-port
controller-name
controller-resource-download-limit
controller-uuid
features
identity-public-key
identity-url
juju-db-snap-channel
juju-ha-space
juju-mgmt-space
login-token-refresh-url
max-agent-state-size
max-charm-state-size
max-debug-log-duration
max-prune-txn-batch-size
max-prune-txn-passes
max-txn-log-size
metering-url
migration-agent-wait-time
model-logfile-max-backups
model-logfile-max-size
model-logs-size
mongo-memory-profile
prune-txn-query-count
prune-txn-sleep-time
public-dns-address
query-tracing-enabled
query-tracing-threshold
set-numa-control-policy
state-port
is the number of old agent/controller log files
to keep (compressed).
Type: integer
Default value: 2
Can be changed after bootstrap: yes
is the maximum file size in MB of each
agent/controller log file.
Type: string
Default value: 100M
agent-ratelimit-max
agent-ratelimit-max
is the maximum size of the token bucket used to
ratelimit the agent connections.
Type: integer
Default value: 10
is the time taken to add a new token to the bucket.
This effectively says that we can have a new agent connect per duration specified.
Type: duration
Default value: 250ms
allow-model-access
allow-model-access
sets whether the controller will allow users to
connect to models they have been authorized for, even when
they don’t have any access rights to the controller itself.
Type: boolean
Default value: false
Can be changed after bootstrap: no
api-port
api-port
is the port used for api connections.
Type: integer
Default value: 17070
api-port-open-delay
api-port-open-delay
is a duration that the controller will wait
between when the controller has been deemed to be ready to open
the api-port and when the api-port is actually opened. This value
is only used when a controller-api-port value is set.
Type: duration
Default value: 2s
limits the number of concurrent resource download
requests from unit agents which will be served. The limit is per application.
Use a value of 0 to disable the limit.
Type: integer
Default value: 0
determines whether the audit log will
contain the arguments passed to API methods.
Type: boolean
is a list of Facade.Method names that
aren’t interesting for audit logging purposes. A conversation
with only calls to these will be excluded from the
log. (They’ll still appear in conversations that have other
interesting calls though.).
Type: list[string]
is the number of old audit log files to keep
(compressed).
Type: integer
Default value: 10
audit-log-max-size
audit-log-max-size
is the maximum size for the current audit log
file, eg “250M”.
Type: string
Default value: 300M
auditing-enabled
auditing-enabled
determines whether the controller will record
auditing information.
Type: boolean
Default value: true
autocert-dns-name
autocert-dns-name
sets the DNS name of the controller. If a
client connects to this name, an official certificate will be
automatically requested. Connecting to any other host name
will use the usual self-generated certificate.
Type: string
autocert-url
autocert-url
sets the URL used to obtain official TLS
certificates when a client connects to the API. By default,
certficates are obtains from LetsEncrypt. A good value for
testing is
“https://acme-staging.api.letsencrypt.org/directory”.
Type: string
ca-cert
ca-cert
is the key for the controller’s CA certificate attribute.
caas-image-repo
caas-image-repo
sets the docker repo to use
for the jujud operator and mongo images.
Type: string
This key is deprecated.
sets the URL of the docker image
used for the application operator.
Deprecated: use caas-image-repo
Type: string
controller-api-port
controller-api-port
is an optional port that may be set for controllers
that have a very heavy load. If this port is set, this port is used by
the controllers to talk to each other - used for the local API connection
as well as the pubsub forwarders, and the raft workers. If this value is
set, the api-port isn’t opened until the controllers have started
properly.
Type: integer
controller-name
controller-name
is the canonical name for the controller.
Type: string
requests from unit agents which will be served. The limit is for the combined total
of all applications on the controller.
Type: integer
Default value: 0
controller-uuid
controller-uuid
is the key for the controller UUID attribute.
features
features
allows a list of runtime changeable features to be updated.
Type: list[string]
identity-public-key
identity-public-key
sets the public key of the identity manager.
Use this when users should be managed externally rather than
created locally on the controller.
Type: string
identity-url
identity-url
sets the URL of the identity manager.
Type: string
selects the channel to use when installing Mongo
snaps for focal or later. The value is ignored for older releases.
Type: string
Default value: 4.4/stable
juju-ha-space
juju-ha-space
is the network space within which the MongoDB replica-set
should communicate.
Type: string
juju-mgmt-space
juju-mgmt-space
is the network space that agents should use to
communicate with controllers.
Type: string
sets the URL of the login JWT well-known endpoint.
Use this when authentication/authorisation is done using a JWT in the
login request rather than a username/password or macaroon and a local
permissions model.
Type: string
is the maximum allowed size of internal state
data that agents can store to the controller in bytes. A value of 0
disables the quota checks although in principle, mongo imposes a
hard (but configurable) limit of 16M.
Type: integer
Default value: 524288
is the maximum allowed size of charm-specific
per-unit state data that charms can store to the controller in
bytes. A value of 0 disables the quota checks although in
principle, mongo imposes a hard (but configurable) limit of 16M.
Type: integer
Default value: 2097152
is used to provide a backstop to the execution of a
debug-log command. If someone starts a debug-log session in a remote
screen for example, it is very easy to disconnect from the screen while
leaving the debug-log process running. This causes unnecessary load on
the API server. The max debug-log duration has a default of 24 hours,
which should be more than enough time for a debugging session.
Type: duration
Default value: 24h0m0s
(deprecated) is the maximum number of transactions
we will evaluate in one go when pruning. Default is 1M transactions.
A value <= 0 indicates to do all transactions at once.
Type: integer
Default value: 1000000
(deprecated) is the maximum number of batches that
we will process. So total number of transactions that can be processed
is max-prune-txn-batch-size
* max-prune-txn-passes
. A value <= 0 implies
‘do a single pass’. If both max-prune-txn-batch-size
and max-prune-txn-passes
are 0, then the default value of 1M BatchSize and 100 passes
will be used instead.
Type: integer
Default value: 100
max-txn-log-size
max-txn-log-size
is the maximum size the of capped txn log collection, eg “10M”.
Type: string
Default value: 10M
metering-url
metering-url
is the URL to use for metrics.
Type: string
Default value: https://api.jujucharms.com/omnibus/v3
is the maximum time that the migration-master
worker will wait for agents to report for a migration phase when
executing a model migration.
Type: duration
Default value: 15m0s
is the number of old model
log files to keep (compressed).
Type: integer
Default value: 2
is the maximum size of the log file written out by the
controller on behalf of workers running for a model.
Type: string
Default value: 10M
model-logs-size
model-logs-size
is the size of the capped collections used to hold the
logs for the models, eg “20M”. Size is per model.
Type: string
Default value: 20M
sets the memory profile for MongoDB. Valid values are:
- “low”: use the least possible memory
- “default”: use the default memory profile.
Type: string
Default value: default
is the number of transactions to read in a single query.
Minimum of 10, a value of 0 will indicate to use the default value (1000).
Type: integer
Default value: 1000
is the amount of time to sleep between processing each
batch query. This is used to reduce load on the system, allowing other
queries to time to operate. On large controllers, processing 1000 txs
seems to take about 100ms, so a sleep time of 10ms represents a 10%
slowdown, but allows other systems to operate concurrently.
A negative number will indicate to use the default, a value of 0
indicates to not sleep at all.
Type: duration
Default value: 10ms
public-dns-address
public-dns-address
is the public DNS address (and port) of the controller.
Type: string
returns whether query tracing is enabled. If so, any
queries which take longer than query-tracing-threshold
will be logged.
Type: boolean
returns the “threshold” for query tracing. Any
queries which take longer than this value will be logged (if query tracing
is enabled). The lower the threshold, the more queries will be output. A
value of 0 means all queries will be output.
Type: duration
Default value: 1s
(true/false) is deprecated.
Use to configure whether mongo is started with NUMA
controller policy turned on.
Type: boolean
state-port
state-port
is the port used for mongo connections.
Type: integer
Default value: 37017
