Configuration > List of controller configuration keys >
juju-mgmt-space
See also: Space
This document describes the juju-mgmt-space
controller configuration key.
Key | Type | Default | Valid values | Purpose |
juju-mgmt-space |
string | null | The network space that agents should use to communicate with controllers. |
The juju-mgmt-space
key is used to apply a network space to the controller.
The space associated with juju-mgmt-space
affects the communication between Juju agents and their controllers by limiting the IP addresses of controller API endpoints to those in the space. If the chosen space results in a lack of agent:controller communication, then a fallback default allows for any IP address to be contacted by the agent. Juju client communication with controllers is unaffected by this option.
Using this option with the bootstrap
or enable-ha
commands effectively adds constraints to machine provisioning. These commands will emit an error if such constraints cannot be satisfied.
