Event > List of events > Lifecycle events
The bulk of the events a charm will see during its lifetime are “lifecycle events”: broadly defined as: events that don’t fit into any other specific category.
Contents:
Complete list of lifecycle events
start
: fired as soon as the unit initialization is complete. -
config-changed
: fired whenever the cloud admin changes the charm configuration *. -
install
: fired when juju is done provisioning the unit. -
<container>-pebble-ready
: fired on kubernetes charms when the requested container is ready. -
leader-elected
: fired on the new leader when juju elects one. -
leader-settings-changed
: fired on all follower units when a new leader is chosen. -
pre-series-upgrade
: fired before the series upgrade takes place. -
post-series-upgrade
: fired after the series upgrade has taken place. -
stop
: fired before the unit begins deprovisioning. -
remove
: fired just before the unit is deprovisioned. -
update-status
: fired automatically at regular intervals by juju. -
upgrade-charm
: fired when the cloud admin upgrades the charm. -
collect-metrics
: (deprecated, will be removed soon)
Lifecycle event triggers
All lifecycle events are triggered in a predictable pattern following a specific action by the administrator (with the exception of update-status
, which triggers on an interval, and <container >-pebble-ready
events, which can occur at any time). For example:
Scenario | Example Command | Resulting Events |
Deploy | juju deploy ./hello-operator.charm |
install -> config-changed -> start -> <container>-pebble-ready |
Scale | juju add-unit -n 2 hello-operator |
Configure | juju config hello-operator thing=foo |
config-changed |
Upgrade | juju upgrade-charm hello-operator |
upgrade-charm -> config-changed -> <container>-pebble-ready |
Remove | juju remove-application hello-operator |
stop -> remove |
Exception to the “all lifecycle events are fired in a predictable pattern following cloud admin actions” rule is <container>-pebble-ready
. As kubernetes pods can churn autonomously (outside of juju’s control), it can happen that the container comes and goes at unpredictable times. When that happens, the charm will receive again <container>-pebble-ready
. See the page on pebble-ready
for more details.
Lifecycle events in Ops
In ops
, all lifecycle events are accessible via CharmBase
's on
attribute.
So you typically want to observe these events by doing:
# in MyCharm(CharmBase) __init__():
self.framework.observe(self.on.start, self._on_start)
self.framework.observe(self.on.install, self._on_install)
