Hi Jorge!
I solved the problem in my Juju Controller, doing this:
juju ssh -m controller 0
ubuntu@juju-controller:~$ sudo su
root@juju-controller:/home/ubuntu
# cd /var/lib/juju/gui/f98f377d076dda630d80edc37f6fb6c475cac7f65d1dde4b525128d575db1192/static/gui/build/app/
** Note that the looong characters folder name maybe change on your controller.
# cp init-pkg-min.js init-pkg-min.backup
# vi init-pkg-min.js
Inside vim, search using slash /&include=revision-info
It will find some text like this:
...de=published&include=resources[&include=revision-info]&include...
delete only: "&include=revision-info"
save it using :wq! or :x
Like it said hatch, the Juju GUI goes to api.jujucharms.com, and uses the parameter revision-info, something like this:
https://api.jujucharms.com/charmstore/v5/bundle/hadoop-spark-63/meta/any?.....&include=revision-info&....
And the API server responses an a ugly 403 - Forbidden.
If you remove the &include=revision-info the API server return the JSON content correctly.
Sorry for my bad english, i hope that this can help you.
