The Juju team is proud to release Juju 2.7.5! This is a bugfix release for the 2.7 series. It includes improvements to improve the stability and memory of Juju agents. All users are recommended to upgrade.
To learn more, about this release–and Juju’s release process in general–watch 2 minutes from the recent office hours (starts at 25:20):
This release includes fixes to the following issues:
- LP #1818359 - network_get() missing information for providers without subnet discovery
- LP #1819365 - Zone constraints causes placement to fail although there available machines
- LP #1841705 - Missing regions in Azure
- LP #1860083 - failed to deploy bundle with “suitable availability zone for machine not found”
- LP #1865229 - relation-get --app fails on non-leader units (peer relations)
- LP #1867886 - 3.22 LXD change in default lxd profile
- LP #1866320 - juju requires --force for unreleased versions
- LP #1865901 - memory leak in agent log rotation
The full listing can be found in the milestone page. Look for issues classified as “Fix Released”.
How do I install Juju?
Other packages are available for a variety of platforms, including Windows and macOS. Refer to the full Juju installation documentation.
Those subscribed to a snap channel should be automatically upgraded. If you’re using the PPA or Homebrew for macOS, you should see an upgrade available.
How do I upgrade?
Upgrading Juju is a multi-step process:
- upgrade the client (the Juju binary that you interact with on the command-line)
- (recommended) verify that the client upgrade was successful
- (recommended) back up the controller
- upgrade the controller
- upgrade models
Upgrade the client
If you’ve installed Juju via the snap, your Juju will automatically be installed overnight. To force the update, run:
snap refresh juju
If you’re using the PPA:
sudo apt update
sudo apt upgrade
On Homebrew for macOS:
brew update
brew upgrade
Check version
To prevent any confusion in later steps, ensure that you’re using the new Juju version.
juju version
Check your $PATH environment variable and that you’ve installed the new version correctly.
On Linux and macOS, use the env command to inspect the environment. On MS Windows, use SET.
Backing up
juju create-backup
Upgrading controllers
Juju includes a command that instructs the controller to upgrade itself to the latest version.
juju upgrade-controller
How to upgrade the controller
First, check that you’re interacting with the intended controller. The juju models command reports the current controller on the first line.
juju models
To verify what will occur, use the --dry-run option.
When you’re happy, omit the flag:
Upgrade models
Your models remain at the same version until you have explicitly told Juju to upgrade them.
juju upgrade-model
How to upgrade your model(s)
Check that you’re operating in the correct model. juju model highlights the current model with an asterisk:
juju models
juju upgrade-juju --dry-run
juju upgrade-juju
Further instructions
Juju’s documentation pages provide detailed information about the upgrade process:
Feedback Appreciated!
We encourage everyone to let us know how you’re using Juju. Please ask questions on on Discourse, send us a message to our Twitter account @juju_devops, tweet using the hashtag #juju_devops, and chat with us at #juju on Freenode via IRC or Matrix.
