Install behind a web proxy
This guide describes how to install Charmed Kubeflow (CKF) behind a web proxy.
Prepare your environment
Before installing CKF, first you need to set up your client with the required proxy settings.
Configure snap
Save the value of your proxy server address for reuse:
PROXY=http://<username>:<password>@<proxy IP>:<proxy port>/
The proxy IP and port are usually given by your network administrator.
Add the username:<password>@ part only if the proxy server is configured with credentials, check with your network administrator.
Set the snap proxy settings:
sudo snap set system proxy.http=$PROXY
sudo snap set system proxy.https=$PROXY
This will enable you to install snap packages.
Now restart the snap service:
sudo systemctl restart snapd.service
Configure MicroK8s
Install Microk8s:
sudo snap install microk8s --classic --channel=1.29-strict/stable
Add the current user to the Microk8s group:
sudo usermod -a -G snap_microk8s $USER
newgrp snap_microk8s
This way you don’t have to use sudo for every Microk8s command.
Enable microk8s add-ons needed to run Charmed Kubeflow. Note that the metallb range can change depending on the use case and the environment:
sudo microk8s enable dns:$(resolvectl status | grep "Current DNS Server" | awk '{print $NF}')	# This sets the dns to your current nameserver
sudo microk8s enable storage ingress metallb:10.64.140.43-10.64.140.49
Get the value cluster-cidr, stored in /var/snap/microk8s/current/args/kube-proxy, and save it in a variable:
cat /var/snap/microk8s/current/args/kube-proxy | grep cluster-cidr
You should see an output similar to this:
--cluster-cidr=<cluster cidr> # save this value
CLUSTER_CIDR=<cluster cidr>
Repeat the process with service-cluster-ip-range, stored in /var/snap/microk8s/current/args/kube-apiserver:
cat /var/snap/microk8s/current/args/kube-apiserver | grep service-cluster-ip-range
-service-cluster-ip-range=<service cluster ip range>  # save this value
SERVICE_CIDR=<service cluster ip range>
You will need these two values in the next step and later when installing Juju.
See MicroK8s | Installing behind a proxy for more details.
Get the Internal IP of the nodes where your cluster is running. You can check that by running:
microk8s kubectl get nodes -o wide
Take note of the INTERNAL-IP value. Save the IP(s) in a variable with suffix /24, comma-separated if you have a multi-node cluster.
NODE_IP=<nodes internal ip(s)>/24
Set the proxy settings in containerd-env. Modify the containerd-env file located in ${SNAP_DATA}/args/containerd-env (normally /var/snap/microk8s/current/args/containerd-env):
HTTPS_PROXY=http://<username>:<password>@<proxy IP>:<proxy port>/
NO_PROXY=<cluster-cidr>,<service-cluster-ip-range>,<nodes internal ip(s)>/24,127.0.0.1
Restart the microk8s snap to pick up the changes:
sudo snap restart microk8s
Check that Microk8s is running with the desired add-ons:
microk8s status
microk8s is running
high-availability: no
  datastore master nodes: 127.0.0.1:19001
  datastore standby nodes: none
addons:
  enabled:
    dns                  # (core) CoreDNS
    ha-cluster           # (core) Configure high availability on the current node
    hostpath-storage     # (core) Storage class; allocates storage from host directory
    ingress              # (core) Ingress controller for external access
    metallb              # (core) Loadbalancer for your Kubernetes cluster
    storage              # (core) Alias to hostpath-storage add-on, deprecated
Configure Juju
Export the system proxy settings used by the Juju client. Make sure to set metallb as you configured it when installing Microk8s. Make sure to replace <hostname> with your own hostname.
export http_proxy=$PROXY
export https_proxy=$PROXY
export no_proxy=$CLUSTER_CIDR,\
$SERVICE_CIDR\
127.0.0.1,\
$NODE_IP,\
<hostname>,\
.svc,\
.local,\
10.64.140.0/24,\  # This is the metallb IP range
.nip.io
Install Juju
sudo snap install juju --classic --channel=3.4/stable
Create a Juju controller in your Microk8s cluster and set the proxy model default values. Change metallb if you configured it differently.
juju bootstrap microk8s uk8s --model-default juju-http-proxy=$http_proxy \
--model-default juju-https-proxy=$https_proxy \
--model-default juju-no-proxy=$no_proxy
Add Juju model
juju add-model kubeflow
Make sure Kubeflow model has your proxy settings, run:
juju model-config
You should see the proxy settings in the juju-http-proxy, juju-https-proxy and juju-no-proxy variables.
Deploy CKF
To deploy CKF and access its dashboard, follow the steps provided in the general installation guide.
Use Kubeflow components behind a proxy
Notebooks
Apply the following PodDefault to your user namespace so each notebook you create will have proxy configurations set. The NO_PROXY and no_proxy values would be the same as you configured in the Juju model.
cat <<EOF | kubectl apply -n $USER_NAMESPACE -f -
apiVersion: kubeflow.org/v1alpha1
kind: PodDefault
metadata:
spec:
  desc: Add proxy settings
  env:
  - name: HTTP_PROXY
    value: http://10.0.1.119:3128/ # replace with $PROXY
  - name: http_proxy
  - name: HTTPS_PROXY
  - name: https_proxy
  - name: NO_PROXY
    value: <cluster cidr>,<service cluster ip range>,127.0.0.1,<nodes internal ip(s)>/24,<cluster hostname>,.svc,.local
  - name: no_proxy
    value: <cluster cidr>,<service cluster ip range>,127.0.0.1,<nodes internal ip(s)>/24,<cluster hostname>,.svc,.local,.kubeflow
  selector:
    matchLabels:
      notebook-proxy: "true"
EOF
You should now be able to see Add proxy settings when creating a new notebook under Advanced Options > Configurations. Always select that option.
Katib
Before running a Katib experiment, add your proxy environment variables to your experiment definition for each container under spec.trialTemplate.trialSpec.spec.template.spec.containers:
env:
  - name: HTTP_PROXY
  - name: http_proxy
  - name: HTTPS_PROXY
  - name: https_proxy
Expand to see full Katib experiment example
apiVersion: kubeflow.org/v1beta1
kind: Experiment
metadata:
spec:
  objective:
    type: maximize
    goal: 0.99
    objectiveMetricName: Validation-accuracy
    additionalMetricNames:
      - Train-accuracy
  algorithm:
    algorithmName: grid
  parallelTrialCount: 1
  maxTrialCount: 1
  maxFailedTrialCount: 1
  parameters:
    - name: lr
      parameterType: double
      feasibleSpace:
        min: "0.001"
        max: "0.01"
        step: "0.001"
    - name: num-layers
      parameterType: int
      feasibleSpace:
        min: "2"
        max: "5"
    - name: optimizer
      parameterType: categorical
      feasibleSpace:
        list:
          - sgd
          - adam
          - ftrl
  trialTemplate:
    primaryContainerName: training-container
    trialParameters:
      - name: learningRate
        description: Learning rate for the training model
        reference: lr
      - name: numberLayers
        description: Number of training model layers
        reference: num-layers
      - name: optimizer
        description: Training model optimizer (sdg, adam or ftrl)
        reference: optimizer
    trialSpec:
      apiVersion: batch/v1
      kind: Job
      spec:
        template:
          metadata:
            annotations:
              sidecar.istio.io/inject: "false"
          spec:
            containers:
              - name: training-container
                image: docker.io/kubeflowkatib/mxnet-mnist:latest
                command:
                  - "python3"
                  - "/opt/mxnet-mnist/mnist.py"
                  - "--batch-size=64"
                  - "--lr=${trialParameters.learningRate}"
                  - "--num-layers=${trialParameters.numberLayers}"
                  - "--optimizer=${trialParameters.optimizer}"
                env:
                  - name: HTTP_PROXY
                  - name: http_proxy
                  - name: HTTPS_PROXY
                  - name: https_proxy
            restartPolicy: Never
Pipelines
If your pipeline needs to download data or pull an image, you can inject your proxy environment variables into a pipeline from inside a notebook with the KFP SDK as done in this example notebook.
Istio
If needed, configure proxy settings for Istio as follows:
kubectl apply -n kubeflow -f - <<EOF
apiVersion: networking.istio.io/v1beta1
kind: ServiceEntry
metadata:
spec:
  hosts:
  - my-company-proxy.com # ignored
  addresses:
  - 10.0.1.119/32 # replace with proxy IP
  ports:
  - number: 3128 # replace with proxy port
    protocol: TCP
EOF
Hi,
It is mentioned in the document to install microk8s from channel 1.24/stable which is a very older version.
And for the juju installation, it is given as:
which installs the version 3.5.3 nowadays.
With this version of juju, it is not possible to bootstrap a controller within microk8s:
ERROR "/var/snap/juju/28060/microk8s/credentials/client.config" does not exist: juju "3.5.3" can only work with strictly confined microk8s
So, the document should be reviewed.
