HTTP request Lego provider
A Juju charm deploying and managing HTTP request Lego provider on Kubernetes. HTTP request Lego provider is a web application implementing the DNS HTTP request provider as defined by ACME to manage DNS records.
This charm simplifies initial deployment and operations of the HTTP request Lego provider on Kubernetes, enabling the automation of DNS management. It allows for deployment on many different Kubernetes platforms, from MicroK8s to Charmed Kubernetes and public cloud Kubernetes offerings.
As such, the charm makes it easy for those looking to host their own ACME provider, and gives them the freedom to deploy on the Kubernetes platform of their choice.
For DevOps or SRE teams this charm will make operating HTTP request Lego provider simple and straightforward through Juju’s clean interface. It will allow easy deployment into multiple environments for testing of changes, and supports scaling out for enterprise deployments.
In this documentation
| Tutorials Get started - a hands-on introduction to using the HTTP request Lego provider for new users |
| Reference Technical information - specifications, APIs, architecture |
Contributing to this documentation
Documentation is an important part of this project, and we take the same open-source approach to the documentation as the code. As such, we welcome community contributions, suggestions and constructive feedback on our documentation. Our documentation is hosted on the Charmhub forum to enable easy collaboration. Please use the “Help us improve this documentation” links on each documentation page to either directly change something you see that’s wrong, or ask a question, or make a suggestion about a potential change via the comments section.
If there’s a particular area of documentation that you’d like to see that’s missing, please file a bug.
Project and community
HTTP request Lego Provider is an open-source project that welcomes community contributions, suggestions, fixes and constructive feedback.
- Read our Code of Conduct
- Get support
- Join our online chat
- Contribute and report bugs to the HTTP request Lego Provider
Navigation
Mapping table
| Level | Path | Navlink |
| 1 | tutorial | Tutorial |
| 2 | tutorial-deploy-the-deploy-the-httprequest-lego-provider-charm-for-the-first-time | Deploy the Httprequest Lego Provider charm for the first time |
| 1 | how-to | How to |
| 2 | back-up-restore | Back up and restore |
| 2 | troubleshoot-api-timeouts | Troubleshoot API timeouts |
| 2 | manage-domains | Manage Domains |
| 2 | manage-users | Manage Users |
| 2 | upgrade | Upgrade |
| 1 | reference | Reference |
| 2 | reference-actions | Actions |
| 2 | reference-configurations | Configurations |
| 2 | reference-integrations | Integrations |
| 1 | explanation | Explanation |
| 2 | charm-architecture | Charm architecture |
| 2 | security | Security |
