How to manage domains
To manage the list of domains a user is allowed to view or request changes to, the following actions are available:
allow-domainsrevoke-domainslist-domains
The allow-domains and revoke-domains support the following inputs:
domains: This input is used to allow a user access to a particular domain only. For example, if we runallow-domainswithdomains="example.domain.com", the user will be able to request a certificate forexample.domain.comonly.subdomains: This input is used to allow a user access to all the subdomains under a domain. For example, if we runallow-domainswithsubdomains="example.domain.com", the user will be able to request a certificate for any subdomain underexample.domain.com, but not a certificate forexample.domain.comitself or a wildcard certificate forexample.domain.com.
The above-mentioned commands can be run with one or more of the above inputs at the same time.
Allowing domains
To add domains to the list of allowed domains, run juju run --wait=5s httprequest-lego-provider/0 allow-domains username=example domains="example.domain.com,example2.domain.com" subdomains="example.domain.com,example3.domain.com".
Revoking domains
To remove domains from the list of allowed domains, run juju run --wait=5s httprequest-lego-provider/0 revoke-domains username=example domains="example.domain.com,example2.domain.com" subdomains="example.domain.com,example3.domain.com".
Listing domains
To query the list of allowed domains for a user, run juju run --wait=5s httprequest-lego-provider/0 list-domains username=example and the list of domains will be returned as in
result: |
example:
domains:
example.domain.com, example2.domain.com
subdomains:
example.domain.com, example3.domain.com
You can also query the list of allowed domains for all users by running juju run --wait=5s httprequest-lego-provider/0 list-domains --string-args username='*'
