See first: Juju | How to manage storage
Contents:
Use storage volumes
- Declare the storage in
charmcraft.yaml
- Observe the
storage-attached
event and define an event handler
Declare the storage in charmcraft.yaml
To define the storage that can be provided to the charm, define a storage
section in charmcraft.yaml
that lists the storage volumes and information about each storage. For example, for a transient filesystem storage mounted to /cache/
that is at least 1GB in size:
storage:
local-cache:
type: filesystem
description: Somewhere to cache files locally.
minimum-size: 1G
properties:
- transient
See more: File
charmcraft.yaml
>storage
For Kubernetes charms, you also need to define where on the workload container the volume will be mounted. For example, to mount a similar cache filesystem in /var/cache/
storage:
local-cache:
type: filesystem
# The location is not required here, because it defines the location on
# the charm container, not the workload container.
minimum-size: 1G
properties:
- transient
containers:
web-service:
resource: app-image
mounts:
- storage: local-cache
See more: File
charmcraft.yaml
>containers
Observe the storage-attached
In the src/charm.py
file, in the __init__
function of your charm, set up an observer for the storage-attached
event associated with your storage and pair that with an event handler, typically a holistic one. For example:
self.framework.observe(self.on.cache_storage_attached, self._update_configuration)
See more:
ops.StorageAttachedEvent
, Juju SDK | Holistic vs delta charms
Storage volumes will be automatically mounted into the charm container at either the path specified in the location
field in the metadata, or the default location /var/lib/juju/storage/<storage-name>
. However, your charm code should not hard-code the location, and should instead use the .location
property of the storage object.
Now, in the body of the charm definition, define the event handler, or adjust an existing holistic one. For example, to provide the location of the attached storage to the workload configuration:
def _update_configuration(self, event: ops.EventBase):
"""Update the workload configuration."""
cache = self.model.storages["cache"]
if cache.location is None:
# This must be one of the other events. Return and wait for the storage-attached event.
logger.info("Storage is not yet ready.")
return
try:
self.push_configuration(cache_dir=cache.location)
except ops.pebble.ConnectionError:
# Pebble isn't ready yet. Return and wait for the pebble-ready event.
logger.info("Pebble is not yet ready.")
return
Examples: ZooKeeper ensuring that permission and ownership is correct, Kafka configuring additional storage
Observe the detaching event and define an event handler
In the src/charm.py
function of your charm, set up an observer for the detaching event associated with your storage and pair that with an event handler. For example:
self.framework.observe(self.on.cache_storage_detaching, self._on_storage_detaching)
See more:
ops.StorageDetachingEvent
Now, in the body of the charm definition, define the event handler, or adjust an existing holistic one. For example, to warn users that data won’t be cached:
def _on_storage_detaching(self, event: ops.StorageDetachingEvent):
"""Handle the storage being detached."""
self.unit.status = ops.ActiveStatus("Caching disabled; provide storage to boost performance)
Examples: MySQL handling cluster management, MongoDB updating the set before storage is removed
Request additional storage
Juju only supports adding multiple instances of the same storage volume on machine charms. Kubernetes charms may only have a single instance of each volume.
If the charm needs additional units of a storage, it can request that with the storages.request
method. The storage must be defined in the metadata as allowing multiple, for
example:
storage:
scratch:
type: filesystem
multiple: 1-10
For example, if the charm needs to request two additional units of this storage:
self.model.storages.request("scratch", 2)
The storage will not be available immediately after that call - the charm should
observe the storage-attached
event and handle any remaining setup once Juju
has attached the new storage.
Test storage volume use
See first: Get started with charm testing
You’ll want to add three levels of tests:
Write unit tests
See first: How to write unit tests for a charm
When using Harness for unit tests, use the add_storage()
method to simulate Juju adding storage to the charm. You can either have the method also simulate attaching the storage, or do that explicitly with the attach_storage()
method. In this example, we verify that the charm responds as expected to storage attached and detaching events:
@pytest.fixture()
def harness():
yield ops.testing.Harness(MyCharm)
harness.cleanup()
def test_storage_attached(harness):
# Add one instance of the expected storage to the charm. This is before `.begin()` is called,
# so will not trigger any events.
storage_id = harness.add_storage("cache", 1)
harness.begin()
# Simulate Juju attaching the storage, which will trigger a storage-attached event on the charm.
harness.attach_storage(storage_id)
# Assert that it was handled correctly.
assert ...
def test_storage_detaching(harness):
storage_id = harness.add_storage("cache", 1, attach=True)
harness.begin()
# Simulate the harness being detached (.remove_storage() would simulate it being removed
# entirely).
harness.remove_storage(storage_id)
# Asser that it was handled correctly.
assert ...
See more:
ops.testing.Harness.add_storage
,ops.testing.Harness.attach_storage
,ops.testing.Harness.detach_storage
,ops.testing.harness.remove_storage
Write scenario tests
See first: How to write scenario tests for a charm
When using Scenario for unit tests, to verify that the charm state is as expected after storage changes, use the run
method of the Scenario Context
object. For example, to provide the charm with mock storage:
# Some charm with a 'foo' filesystem-type storage defined in its metadata:
ctx = scenario.Context(MyCharm)
storage = scenario.Storage("foo")
# Set up storage with some content:
(storage.get_filesystem(ctx) / "myfile.txt").write_text("helloworld")
with ctx.manager("update-status", scenario.State(storage=[storage])) as mgr:
foo = mgr.charm.model.storages["foo"][0]
loc = foo.location
path = loc / "myfile.txt"
assert path.exists()
assert path.read_text() == "helloworld"
myfile = loc / "path.py"
myfile.write_text("helloworlds")
# Verify that the contents are as expected afterwards.
assert (
storage.get_filesystem(ctx) / "path.py"
).read_text() == "helloworlds"
If a charm requests adding more storage instances while handling some event, you
can inspect that from the Context.requested_storage
API.
ctx.run('some-event-that-will-request-more-storage', scenario.State())
# The charm has requested two 'foo' storage volumes to be provisioned:
assert ctx.requested_storages['foo'] == 2
Requesting storage volumes has no other consequence in Scenario. In real life, this request will trigger Juju to provision the storage and execute the charm again with foo-storage-attached. So a natural follow-up Scenario test suite for this case would be:
foo_0 = scenario.Storage('foo')
# The charm is notified that one of the storage volumes it has requested is ready:
ctx.run(foo_0.attached_event, State(storage=[foo_0]))
foo_1 = scenario.Storage('foo')
# The charm is notified that the other storage is also ready:
ctx.run(foo_1.attached_event, State(storage=[foo_0, foo_1]))
See more: Scenario storage testing
Write integration tests
See first: How to write integration tests for a charm
To verify that adding and removing storage works correctly against a real Juju instance, write an integration test with pytest_operator
. For example:
# This assumes there is a previous test that handles building and deploying.
async def test_storage_attaching(ops_test):
# Add a 1GB "cache" storage:
await ops_test.model.applications[APP_NAME].units[0].add_storage("cache", size=1024*1024)
await ops_test.model.wait_for_idle(
apps=[APP_NAME], status="active", timeout=600
# Assert that the storage is being used appropriately.
Contributors:@tmihoc, @tony-meyer
