How to migrate Charmed Pyroscope from v1 to v2
Pyroscope 2.1 and later use a new storage architecture. They cannot query profiles written by Pyroscope 1, so migrate by deploying the newer version beside your existing deployment.
Keep the v1 deployment until you no longer need its profile history. The old data remains in its S3 bucket, but Pyroscope 2.1 and later cannot read it.
Before migrating, make sure you have:
  • a Charmed Pyroscope deployment running Pyroscope 1.x
  • a separate S3 bucket for Pyroscope 2.1 or later
  • enough capacity to run both deployments during the migration
  • the charm channel that ships Pyroscope 2.1 or later
Note: The 2/edge channel shown in older Charmed Pyroscope guides ships Pyroscope 1.x. Replace <v2-channel> below with a channel that ships Pyroscope 2.1 or later.
Deploy Pyroscope 2.1 or later
Deploy the newer version with application names that do not conflict with your v1 deployment. The pyroscope-v2 names below are examples:
juju deploy pyroscope-coordinator-k8s pyroscope-v2 \
  --channel <v2-channel> --trust
juju deploy pyroscope-worker-k8s pyroscope-v2-worker \
  --channel <v2-channel> --trust --config role-all=true
juju integrate pyroscope-v2 pyroscope-v2-worker
Configure a separate s3-integrator for the new bucket, then integrate it with the new coordinator:
juju deploy s3-integrator pyroscope-v2-s3 --channel 2/stable --trust
juju config pyroscope-v2-s3 endpoint=<s3-endpoint> bucket=<v2-bucket>
juju run pyroscope-v2-s3/leader sync-s3-credentials \
  access-key=<access-key> secret-key=<secret-key>
juju integrate pyroscope-v2:s3 pyroscope-v2-s3
Wait until the coordinator and worker report active in juju status.
For a production deployment, use separate workers for the required roles instead of the single role-all worker shown here.
Send profiles to Pyroscope 2.1 or later
Integrate each charmed application with the new coordinator:
juju integrate <application>:profiling pyroscope-v2:profiling
Keep the application’s existing relation with v1 while you verify the new deployment. Applications using a fixed Pyroscope URL must be pointed at the new coordinator separately.
Verify the new deployment
Do not rely only on juju status or a successful push. Confirm that a recent profile can be queried from the new datasource in Grafana Explore.
Keep using both deployments until profiles captured before the new version was deployed have passed the history window you need from v1.
Complete the migration
Remove each application’s relation with the v1 coordinator:
juju remove-relation <application>:profiling pyroscope:profiling
Check again that new profiles appear in the new deployment. When you no longer need the v1 profile history, remove the v1 coordinator and all its worker applications.
If you need to stop before removing v1, remove the new relations and continue using the original deployment. No data is converted or moved during this process.
