Charmed Pyroscope HA
Charmed Pyroscope HA is a solution that handles deployment, scaling, and Day 2 operations specific to Grafana Pyroscope, a distributed continuous profiling backend by Grafana Labs.
The solution consists of two charms which have distinct responsibilities:
Together, these two charms drive the Grafana Pyroscope application, and can be composed with other operators to deliver a complex application or service. In particular, you can integrate the coordinator charm with COS to collect and visualise continuous profiling data, enhancing your observability toolkit.
Grafana Pyroscope allows you to aggregate continuous profiling data from all your charmed applications with high availability, multi-tenancy, and durable storage.
This solution is:
  • intended to be used together with grafana-k8s.
  • intended to be used with other charms that will push their profiles into it for storage and querying.
In this documentation
Tutorial
Get started - a hands-on introduction for new users deploying the charmed operator.
How-to guides
Step-by-step guides covering key operations and common tasks
Explanation
Concepts - discussion and clarification of key topics
Reference
Technical information - specifications, APIs, architecture
Project and community
Charmed Pyroscope is part of the Canonical Observability Stack. It’s an open source project that warmly welcomes community projects, contributions, suggestions, fixes and constructive feedback.
Thinking about using the Canonical Observability Stack for your next project? Get in touch!
Navigation
Level Path Navlink
1 Tutorials Tutorials
1 How-To How-To Guides
2 How to deploy Charmed Pyroscope How to deploy Charmed Pyroscope
2 How to enable TLS for Charmed Pyroscope How to enable TLS for Charmed Pyroscope
2 How to integrate with Pyroscope over profiling How to integrate with charmed Pyroscope over profiling
1 Explanation Explanation
2 Ingressing the UI and exposing the grpc profile ingestion endpoint Charmed Pyroscope ingressing model
2 How to migrate Charmed Pyroscope from v1 to v2 How to migrate Charmed Pyroscope from v1 to v2
1 Reference Reference
