See first: Juju | Leader
Contents:
Observe the leader-elected
event and define an event handler
In the src/charm.py
file, in the __init__
function of your charm, set up an observer for the leader-elected
event and pair that with an event handler. For example:
self.framework.observe(self.on.leader_elected, self._on_leader_elected)
See more:
ops.LeaderElectedEvent
Now, in the body of the charm definition, define the event handler. For example, the handler below will update a configuration file:
def _on_leader_elected(self, event: ops.LeaderElectedEvent):
self.reconfigure(leader=self.unit)
Examples: Tempo reconfiguring ingress on leadership change, Kubeflow Dashboard using a holistic handler to configure on leadership change and other events
To have the leader notify other units about leadership changes, change data in a peer relation.
See more: Peer Relations
In the past, this was done by observing a leader-setting-changed
event, which is now deprecated.
Commonly, other event handlers will need to check for leadership. For example, only the leader unit can change charm application secrets, so checks for leadership are needed to guard against non-leaders. For example:
if self.unit.is_leader():
secret = self.model.get_secret(label="my-label")
secret.set_content({"username": "user", "password": "pass"})
Note that Juju guarantees leadership for only 30 seconds after a leader-elected
event or an is-leader
check. If the charm code may run longer, then extra
is_leader()
calls should be made to ensure that the unit is still the leader.
Test leadership management
See first: Get started with charm testing
You’ll want to add three levels of tests:
Write unit tests
See first: How to write unit tests for a charm
When using Harness for unit tests, use the set_leader()
method to control whether the unit is the leader. For example, to verify that leadership change is handled correctly:
@pytest.fixture()
def harness():
yield ops.testing.Harness(MyCharm)
harness.cleanup()
def test_new_leader(harness):
# Before the test, the unit is not leader.
harness.set_leader(False)
harness.begin()
# Simulate Juju electing the unit as leader.
harness.set_leader(True)
# Assert that it was handled correctly.
assert ...
def test_leader_sets_secrets(harness):
# The unit is the leader throughout the test, and no leader-elected event
# is emitted.
harness.begin()
secret_id = harness.add_model_secret(APP_NAME, content={"secret": "sssh"})
harness.update_config(secret_option=secret_id)
# Assert that the config-changed handler set additional secret metadata:
assert ...
See more:
ops.testing.Harness.set_leader
Write scenario tests
See first: How to write scenario tests for a charm
When using Scenario for unit tests, pass the leadership status to the State
. For example:
class MyCharm(ops.CharmBase):
def __init__(self, framework):
super().__init__(framework)
framework.observe(self.on.start, self._on_start)
def _on_start(self, _):
self.unit.status = ops.ActiveStatus('I rule')
else:
self.unit.status = ops.ActiveStatus('I am ruled')
@pytest.mark.parametrize('leader', (True, False))
def test_status_leader(leader):
ctx = scenario.Context(MyCharm, meta={"name": "foo"})
out = ctx.run('start', scenario.State(leader=leader))
assert out.unit_status == ops.ActiveStatus('I rule' if leader else 'I am ruled')
Write integration tests
See first: How to write integration tests for a charm
Juju is in sole control over which unit is the leader, so leadership changes are
not usually tested with integration tests. If this is required, then the test
needs to remove the leader unit (machine charms) or run juju_stop_unit
in the
charm container (Kubernetes charms). The test then needs to wait up to 60 seconds
for Juju to elect a new leader.
More commonly, an integration test might want to verify that leader and non-leader behaviour is as expected. For example:
async def get_leader_unit(ops_test, app, model=None):
"""Utility method to get the current leader unit."""
leader_unit = None
if model is None:
model = ops_test.model
for unit in model.applications[app].units:
if await unit.is_leader_from_status():
leader_unit = unit
break
return leader_unit
Examples: Zookeeper testing upgrades, postgresql testing password rotation action
See more:
juju.unit.Unit.is_leader_from_status
Contributors:@tmihoc, @tony-meyer
