How To Fix A Volume Attachment Failure Against An OpenStack Instance
Introduction
Duration: 30:00
When updating QEMU packages, instances that started prior to the upgrade can experience issues attaching volumes to it.
This is due to LP#1847361. In summary, this bug causes the new QEMU version to not recognize the old QEMU modules for attaching volumes to VMs.
This bug is especially bad in Kubernetes deployments on top of OpenStack. A pod will get stuck attempting to create a container when it tries to attach the PVC (and by consequence, attach cinder volume to k8s worker VM). This playbook intends to explain how to identify if the QEMU bug is the root problem, how to fix, and proper procedure for handling the k8s situation.
Requirements
  1. A deployed CDK environment on top of an OpenStack environment (such as OpenStack-base)
  2. OpenStack is configured with valid credentials (e.g. source novarc, represents
    the OpenStack credentials, belonging to the managed OpenStack service on top of which the overcloud OpenStack service is deployed. If the credentials are missing, ask the managed OpenStack administrator)
See tutorial How to deploy openstack-on-openstack, and bootstrap a Juju env on top of it.
Environment preparation
For the purposes of this tutorial, it is necessary to have the PVC storage attached to any k8s pod and then upgrade QEMU.
Cinder volume
The following yaml configuration file is used to create an 8 GB cinder volume.
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
spec:
  storageClassName: cdk-cinder
  accessModes:
    - ReadWriteOnce
  resources:
    requests:
      storage: 8Gi
The next step will be to create PersistentVolumeClaim (PVC).
kubectl apply -f <pvc-configutation-file>.yaml
QEMU update
the QEMU packages are used by the KVMs running on a nova-compute unit, and it could be upgraded using the following command.
juju run --application nova-compute 'sudo apt install --upgrade qemu'
Identify attachment failures
On the surface, attachment failures won’t give much info on why it’s failing. Nova log on the host will show ERROR messages similar to the following:
2020-11-04 23:48:37.871 1033447 ERROR oslo_messaging.rpc.server libvirt.libvirtError: internal error: unable to execute QEMU command 'device_add': Property 'virtio-blk-device.drive' can't find value 'drive-virtio-disk1'
The following logs in /var/log/libvirt/qemu/${virsh_instance_name}.log also indicate that it’s this specific attachment issue:
Failed to open module: /usr/lib/x86_64-linux-gnu/qemu/block-rbd.so: undefined symbol: RbdAuthMode_lookup
Failed to open module: /var/run/qemu/_Debian_1_2.11+dfsg-1ubuntu7.31_/block-rbd.so: failed to map segment from shared object
Steps to Fix
There are 2 methods of fixing the issue. One method involves explicitly stopping the server and
starting it back up again (reboot doesn’t fix the issue). Alternatively, it’s possible to migrate the instance to another host, and the attached should work after migrating, as this is essentially creating a new VM on the new host.
Start/Stop method
Stop the server:
openstack server stop $instance_uuid
Wait for the server to shutdown completely:
watch openstack server show $instance_uuid -c OS-EXT-STS:power_state -c OS-EXT-STS:task_state -c OS-EXT-STS:vm_state
Start the server:
openstack server start $instance_uuid
Migration Method
Simply live migrate the instance to another host. Here’s an example (may need to add --block-migration or --shared-migration):
openstack server migrate --wait --live-migration $instance_uuid
K8s Attachment Issues
Extra steps must be taken when this problem manifests in a K8s cloud. Care must be taken to drain the K8s worker before actioning the instance. It may be possible to migrate the K8s worker instance without draining, but this hasn’t been explicitly tested. These steps on how to drain (pause and resume) the K8s worker are described in K8s Worker Maintenance Tutorial.
Custom pod: If it’s a custom pod, be aware that using the delete-local-storage=true parameter will result in the loss of locally
stored data in the pod.
