Introduction
Duration: 80:00
This tutorial has been tested on a CDK environment deployed on
the OpenStack-base environment. The OpenStack environment was deployed on top of another managed OpenStack service.
Requirements
There are three prerequisites needed:
- Juju is installed (see Installing Juju)
- Juju controller is up and running (see Creating a controller)
- OpenStack is configured with valid credentials (e.g.
source novarc, represents the OpenStack credentials, belonging to the managed OpenStack environment on top of which OpenStack-base is deployed. If the credentials are missing, ask the managed OpenStack administrator)
OpenStack
Deploy the OpenStack-base bundle with the custom overlay.
Resources overlay
The following overlay must be used if CDK is deployed over OpenStack, otherwise the minimum requirements would not be met, and the kubernetes-master (and worker) units could not be deployed.
applications:
ceph-osd:
storage:
osd-devices: 40GB
nova-compute:
annotations:
constraints: cores=6 mem=8G
Deployment
git clone https://github.com/openstack-charmers/openstack-bundles.git
juju deploy ./openstack-bundles/stable/openstack-base/bundle.yaml --overlay ./openstack-bundles/stable/overlays/openstack-base-virt-overlay.yaml --overlay ./resources-overlay.yaml
Initialize and unseal Vault and create a self-signed root CA
- Wait for the
vault/0unit to be in theblockedstate with messageVault needs to be initialized.juju ssh vault/0 - Initialize Vault deployment. (for more information, look at the official documentation)
export VAULT_ADDR="http://127.0.0.1:8200" vault operator init -key-shares=3 -key-threshold=3 > vault-keys - Unseal all keys and generate root CA.
for key in $(grep -E "Unseal Key .*: " vault-keys | cut -c15- | tail -3) do vault operator unseal $key done - Create a temporary token which will expire after 10 minutes. (for more information visit page)
export VAULT_TOKEN=$(grep -E "Initial Root Token: " vault-keys | cut -c21-) vault token create -ttl=10m - Detach from the
vault/0unit. - Authorize the vault unit.
export VAULT_TOKEN=$(juju ssh vault/0 'grep -E "Initial Root Token: " vault-keys | cut -c21-') juju run-action --wait vault/leader authorize-charm token=$VAULT_TOKEN juju run-action --wait vault/leader generate-root-ca
Add external L3 connectivity
This section deals with the prerequisites for network configuration and is required for the full functionality of the deployed OpenStack. It provides network traffic between individual units.
OpenStack credentials:
Don’t forget to load the managed OpenStack service credentials. (e.g. source novarc, see previous “Requirements” section), which will allow the configuration of objects for the overcloud OpenStack-base service.
- Get OpenStack admin net.
export ADMIN_NET=$(openstack network list --format value | grep admin_net | cut -d" " -f1) - Create a new port for each nova-compute unit. (by default there are 3 units)
unset BRIDGE_INTERFACE_MAPPING # clear value for i in 0 1 2 do # create new port eval $(openstack port create --format shell --prefix port_ --network $ADMIN_NET data-port) echo " create new port with id $port_id and MAC address $port_mac_address" # get ovn chassis ip export ovn_chassis_ip=$(juju status | grep ovn-chassis/$i | tr -s " " | cut -d" " -f5) echo " found ovn-chassis/$i ip address $ovn_chassis_ip" # get ovn chassis id export ovn_chassis_id=$(openstack server list -f value | awk -v IP=$ovn_chassis_ip '$0 ~ IP {print $1}') echo " found ovn-chassis/$i id $ovn_chassis_id" # add port to ovn chassis openstack server add port $ovn_chassis_id $port_id echo " add port $port_id to server $ovn_chassis_id" # set bridge interface mapping variable export BRIDGE_INTERFACE_MAPPING="$BRIDGE_INTERFACE_MAPPING br-ex:$port_mac_address" done - Configure the bridge interface mapping in the
ovn-chassisapplication.juju config ovn-chassis bridge-interface-mappings="$BRIDGE_INTERFACE_MAPPING"
configuring a new interface for ovn-chassis:
After adding and configuring new ports to the ovn-chassis units, you need to run the
juju resolve ovn-chassis/<unit_number> twice for each unit.
Final configuration
The final step is to configure Juju to use the deployed OpenStack environment as cloud provider, and configure it
Don’t forget to get credentials for the new OpenStack. (e.g. source openrc, which should be found in OpenStack bundles repository)
In order to use the overcloud OpenStack service, several configurations are required: flavors, images, networks and security groups. Detailed instructions can be found on OpenStack-base in the “Accessing the cloud” section.
Images - creating focal image
curl https://cloud-images.ubuntu.com/focal/current/focal-server-cloudimg-amd64.img | openstack image create --public --container-format=bare --disk-format=qcow2 focal -
Flavors - creating four basic types of flavors and one use for the bootstrap controller
openstack flavor create --vcpus 1 --ram 1024 --disk 10 --ephemeral 0 m1.tiny openstack flavor create --vcpus 2 --ram 2048 --disk 20 --ephemeral 0 m1.small openstack flavor create --vcpus 2 --ram 4096 --disk 20 --ephemeral 0 m1.medium openstack flavor create --vcpus 4 --ram 4096 --disk 20 --ephemeral 0 m1.large openstack flavor create --vcpus 2 --ram 3584 --disk 20 --ephemeral 0 m1.controller -
Networks - two networks (internal and external) are required for openstack to work
# Configuration example export EXT_SUBNET_RANGE=10.5.0.0/16 export EXT_GATEWAY=10.5.0.1 export EXT_POOL_START=10.5.150.0 export EXT_POOL_END=10.5.200.254 export INT_SUBNET_RANGE=192.168.21.0/24 export INT_DNS=10.5.0.2 openstack network create --external --provider-network-type flat --provider-physical-network physnet1 external_net openstack subnet create --subnet-range $EXT_SUBNET_RANGE --no-dhcp --gateway $EXT_GATEWAY --network external_net --allocation-pool start=$EXT_POOL_START,end=$EXT_POOL_END external_subnet openstack network create internal_net openstack subnet create --network internal_net --subnet-range $INT_SUBNET_RANGE --dns-nameserver $INT_DNS internal_subnet openstack router create provider-router openstack router set --external-gateway external_net provider-router openstack router add subnet provider-router internal_subnet -
Security - needed to enable ssh connectivity
PROJECT_ID=$(openstack project list -f value -c ID --domain admin_domain) SECGRP_ID=$(openstack security group list --project $PROJECT_ID | awk '/default/{print$2}') openstack security group rule create $SECGRP_ID --protocol icmp --ingress --ethertype IPv4 openstack security group rule create $SECGRP_ID --protocol icmp --ingress --ethertype IPv6 openstack security group rule create $SECGRP_ID --protocol tcp --ingress --ethertype IPv4 --dst-port 22 openstack security group rule create $SECGRP_ID --protocol tcp --ingress --ethertype IPv6 --dst-port 22 -
Quota - change quotas to increase the number of instances and security groups that can be created
PROJECT_ID=$(openstack project list -f value -c ID --domain admin_domain) openstack quota set --instances 40 --secgroups 40 $PROJECT_ID -
Keypair - allow ssh access to instances using a customer ssh public key
openstack keypair create --public-key <path_to_publick_key> mykey
The last thing is to add a new OpenStack cloud to Juju, create new credentials and create a controller.
See Using OpenStack with Juju for more information.Tunnel: If your OpenStack environment is not on the local machine, or the remote machine is not reachable directly, you may need to run
sshuttleto redirect all the traffic via a ssh tunnel.
sshuttle -r <user@server> <juju-network>e.g.sshuttle -r jumphost 10.5.0.0/16(find network with
juju status -m controller)-
Add OpenStack as a Juju cloud provider.
juju add-cloud <cloud_name> -f clouds.yaml# cloud configuration example clouds: <cloud_name>: type: openstack auth-types: [userpass] endpoint: https://<keystone_internal_ip>:5000/v3 regions: RegionOne: endpoint: https://<keystone_internal_ip>:5000/v3 ca-certificates: - | -----BEGIN CERTIFICATE----- <your_certificate> -----END CERTIFICATE----- -
Add credentials to the “openstack” cloud.
juju add-credential <cloud_name> -f credentials.yaml# credentials example credentials: <cloud_name>: <credentials name>: auth-type: userpass username: admin password: <user_password> project-domain-name: admin_domain tenant-name: admin user-domain-name: admin_domain version: "3" -
Allow multiple units to land on 3 nova-compute units (edit disk, ram and cpu ratio).
juju config nova-cloud-controller disk-allocation-ratio=10 ram-allocation-ratio=1 cpu-allocation-ratio=4 -
It’s necessary to create metadata for initializing a Juju cloud environment (creating the controller).
IMG_ID=$(openstack image list --name focal -c ID -f value) juju metadata generate-image -d ./simplestreams -i $IMG_ID -s focal -r $OS_REGION_NAME -u $OS_AUTH_URL -
Bootstrap the controller.
EXT_NET=$(openstack network list --name external_net -c ID -f value) INT_NET=$(openstack network list --name internal_net -c ID -f value) juju bootstrap --metadata-source ./simplestreams --model-default external-network=$EXT_NET --model-default network=$INT_NET --model-default use-floating-ip=true --model-default use-default-secgroup=true --config default-series=focal <cloud_name> <controller_name>Proxy: If the environment used to deploy the instances requires a proxy, the following must also be used:
--model-default juju-http-proxy=<proxy_ip>:<proxy_port> --model-default juju-https-proxy=<proxy_ip>:<proxy_port> --model-default juju-no-proxy="10.5.0.0/16".
