Configure with Namecheap DNS plugin information
In this guide, we will go through the steps necessary to use the LEGO Operator for providing certificates to another charm using the namecheap dns plugin.
Create a Juju Model:
juju add-model <your model name>
Deploy the Lego charm:
juju deploy lego --channel 4/edge
Configure the charm with your ACME information:
juju config lego \
server=<your ACME server> \
email=<your email address> \
plugin=namecheap
Lego operator accepts all of the environment variables defined in the LEGO documentation as keys in the secret you’ve provided. Provide the configuration for the httpreq as a juju secret:
$ juju add-secret lego-credentials \
namecheap-api-user=your_user_name \
namecheap-api-key=your_api_key
secret:crr9g37mp25c77tv2atg
$ juju grant-secret lego-credentials lego
$ juju config lego plugin-config-secret-id=crr9g37mp25c77tv2atg
If all of the correct keys are provided, you should see that your charm is now in an active state
demo microk8s-localhost microk8s/localhost 3.4.5 unsupported 14:36:17+03:00
lego active 1 lego 4/edge 7 10.152.183.196 no 0/0 certificate requests are fulfilled
lego/0* active idle 10.1.90.177 0/0 certificate requests are fulfilled
Deploy your charm that requires TLS certificates and integrate it with the Lego charm:
juju deploy <your charm>
juju integrate <your charm> lego
