A Juju charm deploying docker images using gunicorn as default.
This charm simplifies docker image deployment management, allowing us to inject variables to the environment as we see fit. It allows for deployment on many different Kubernetes platforms, from MicroK8s to Charmed Kubernetes](Enterprise Kubernetes for multi-cloud operations | Ubuntu) to public cloud Kubernetes offerings.
As such, the charm makes it easy for those looking to take control of their docker images, use them in a juju environment without having to write a charm from scratch and gives them the freedom to deploy on the Kubernetes platform of their choice.
For DevOps or SRE teams this charm will make docker image testing easier and more manageable. It will allow easy deployment into multiple environments for testing of changes, and supports scaling out for enterprise deployments. of changes, and supports scaling out for enterprise deployments.
Navigation
| Level | Path | Navlink |
| 1 | Tutorial | Tutorial |
| 2 | Getting started | Getting started |
| 1 | How to | How to |
| 2 | Contribute | Contribute |
| 2 | Use cross-model relations | Use cross-model relations |
| 2 | Use a custom dockerfile | Use a custom dockerfile |
| 1 | Explanation | Explanation |
| 2 | Architecture | Architecture |
Redirects
Mapping table
| Path | Location |
