How to contribute
This document explains the processes and practices recommended for contributing enhancements to the Gunicorn-k8s operator.
- Generally, before developing enhancements to this charm, you should consider opening an issue explaining your use case.
- If you would like to chat with us about your use-cases or proposed implementation, you can reach us at Canonical Mattermost public channel or Discourse.
- Familiarising yourself with the Charmed Operator Framework library will help you a lot when working on new features or bug fixes.
- All enhancements require review before being merged. Code review typically examines
- code quality
- test coverage
- user experience for Juju administrators of this charm.
- Please help us out in ensuring easy to review branches by rebasing your pull request branch onto the
mainbranch. This also avoids merge commits and creates a linear Git commit history.
Developing
The code for this charm can be downloaded as follows:
git clone https://github.com/canonical/gunicorn-k8s-operator
You can use the environments created by tox for development:
tox --notest -e unit
source .tox/unit/bin/activate
Testing
tox -e fmt # update your code according to linting rules
tox -e lint # code style
tox -e unit # unit tests
# integration tests (see below for building docker images)
tox -e integration -- --gunicorn-image localhost:32000/gunicorn:latest --statsd-prometheus-exporter-image prom/statsd-exporter
tox # runs 'lint' and 'unit' environments
Build charm
Build the charm in this git repository using:
charmcraft pack
For the integration tests (and also to deploy the charm locally), the gunicorn image is required in the microk8s registry. To enable it:
microk8s enable registry
The following command pushes the required image into the registry:
docker build . -t localhost:32000/gunicorn:latest -f gunicorn.Dockerfile
docker push localhost:32000/gunicorn:latest
Deploy
# Create a model
juju add-model gunicorn-dev
# Enable DEBUG logging
juju model-config logging-config="<root>=INFO;unit=DEBUG"
# Deploy the charm (Assuming you're on amd64)
juju deploy ./gunicorn-k8s_ubuntu-20.04-amd64.charm --resource gunicorn-image='localhost:32000/gunicorn:latest' --resource statsd-prometheus-exporter-image='prom/statsd-exporter'
Canonical contributor agreement
Canonical welcomes contributions to the Indico Operator. Please check out our contributor agreement if you’re interested in contributing to the solution.
