Getting Started
In this tutorial, we will get certificates signed by Let’s Encrypt for the tls-certificates-require charm using the lego-operator
Pre-requisites
- Ubuntu 22.04
- A Juju controller
- A valid domain name from one of the supported DNS Providers from this list.
- The authentication data required for the DNS provider plugin as specified in the documentation of LEGO
- A requirer charm using the
tls-certificates-interface
1. Add the Juju model
juju add-model lego
2. Deploy and Configure the Requirer Charm
In this tutorial we are going to use the tls-certificates-requirer charm, and we will configure it to use our valid domain name.
juju deploy tls-certificates-requirer --config common_name="techtutorial.org" --config sans_dns="techtutorial.org"
3. Deploy and Configure lego
juju deploy lego --channel 4/stable
Configure the Let's Encrypt server. In this tutorial we will use the staging server of Let’s Encrypt
juju config lego server="https://acme-staging-v02.api.letsencrypt.org/directory"
Configure your email
juju config lego email=<your email address>
Configure the plugin.
In this tutorial we will use the hetzner plugin but you can use the plugin of your choice as long as it is supported by LEGO
juju config lego plugin="hetzner"
Next we must add a secret that contains the required configuration for the plugin having the config options as the keys and their values as the values, in the case of hetzner we only need the hetzner API Key, but this varies per plugin so make sure to check the plugin’s documentation like this of hetzner’s
juju add-secret lego-credentials hetzner-api-key=<key>
Grant the secret to the charm
juju grant-secret lego-credentials lego
Configure the charm with the ID of the secret we just created
juju config lego plugin-config-secret-id=<secret id>
Now lego should be in Active state and ready to be integrated with requirer charms.
4. Integrate the charms
juju integrate lego tls-certificates-requirer
5. Validate Certificate
Wait until the charms go into the following states:
lego k8s microk8s/localhost 3.6.4 unsupported 13:04:55Z
lego active 1 lego 4/stable 34 10.152.183.222 no 1/1 certificate requests are fulfilled
tls-certificates-requirer active 1 tls-certificates-requirer latest/stable 143 10.152.183.168 no 1/1 certificate requests are fulfilled
lego/0* active idle 10.1.250.243 1/1 certificate requests are fulfilled
tls-certificates-requirer/0* active idle 10.1.250.212 1/1 certificate requests are fulfilled
We can validate that the certificate was actually signed by Let's Encrypt
juju run tls-certificates-requirer/leader get-certificate \
| yq -r '.certificates | fromjson | .[0].certificate' \
| openssl x509 -text -noout
The output shows that the certificate was signed by Let's Encrypt for techtutorial.org
Certificate:
Data:
Version: 3 (0x2)
Serial Number:
05:e0:c0:af:ed:73:58:25:bd:c4:76:a0:22:f7:a6:3f:27:16
Signature Algorithm: sha256WithRSAEncryption
Issuer: C = US, O = Let's Encrypt, CN = R11
Validity
Not Before: Apr 8 12:05:16 2025 GMT
Not After : Jul 7 12:05:15 2025 GMT
Subject: CN = techtutorial.org
Subject Public Key Info:
Public Key Algorithm: rsaEncryption
Public-Key: (2048 bit)
Modulus:
00:f9:15:c4:61:e0:10:06:c8:f5:33:40:19:e1:b2:
09:21:9e:b5:d0:37:9a:80:01:c9:93:e1:ef:f3:6f:
26:de:4d:0d:5a:5a:94:67:48:d6:be:e1:76:65:62:
7c:b7:e8:ab:31:6c:9d:37:d5:00:a7:e5:74:c4:62:
fb:19:c0:41:68:b8:7d:f6:d6:21:a0:5e:3f:5f:fd:
a8:d9:38:50:3a:21:cb:bd:9f:46:78:02:13:21:95:
88:79:80:d5:87:0d:1b:96:ac:bc:17:1b:46:f9:ba:
a2:90:9a:22:9f:c5:3a:3e:ab:79:b1:0a:0e:c8:f5:
ac:8e:a9:35:b8:a7:60:2b:a5:5c:64:df:7e:48:20:
cc:95:d5:b5:89:c0:ad:20:4f:f7:d4:8f:3b:49:17:
33:35:f2:7e:a8:a5:9a:de:30:dd:36:a9:24:47:97:
a1:fb:cf:67:b6:a2:90:7a:87:cf:8a:6c:64:71:89:
60:bb:f3:35:13:36:1f:e3:16:1c:03:ba:f6:81:d3:
3b:0d:a3:d6:a1:2b:96:4b:30:e4:ad:84:6e:14:c6:
57:09:24:9a:1a:1f:74:dd:4d:89:20:bb:51:f0:fe:
22:f0:8c:76:3e:21:8e:07:a9:66:d6:ee:df:d2:52:
25:ab:ba:7f:00:14:86:b2:d3:19:11:1f:3e:0e:f4:
ce:a7
Exponent: 65537 (0x10001)
X509v3 extensions:
X509v3 Key Usage: critical
Digital Signature, Key Encipherment
X509v3 Extended Key Usage:
TLS Web Server Authentication, TLS Web Client Authentication
X509v3 Basic Constraints: critical
CA:FALSE
X509v3 Subject Key Identifier:
0B:92:5F:73:51:AF:A3:BE:D4:8E:CC:31:8C:E4:63:78:AF:6C:99:5D
X509v3 Authority Key Identifier:
C5:CF:46:A4:EA:F4:C3:C0:7A:6C:95:C4:2D:B0:5E:92:2F:26:E3:B9
Authority Information Access:
OCSP - URI:http://r11.o.lencr.org
CA Issuers - URI:http://r11.i.lencr.org/
X509v3 Subject Alternative Name:
DNS:techtutorial.org
X509v3 Certificate Policies:
Policy: 2.23.140.1.2.1
X509v3 CRL Distribution Points:
Full Name:
URI:http://r11.c.lencr.org/23.crl
CT Precertificate SCTs:
Signed Certificate Timestamp:
Version : v1 (0x0)
Log ID : CC:FB:0F:6A:85:71:09:65:FE:95:9B:53:CE:E9:B2:7C:
22:E9:85:5C:0D:97:8D:B6:A9:7E:54:C0:FE:4C:0D:B0
Timestamp : Apr 8 13:03:46.809 2025 GMT
Extensions: none
Signature : ecdsa-with-SHA256
30:45:02:21:00:8C:9C:E8:1D:F5:E1:78:B8:75:8C:60:
92:CD:EE:2C:70:C4:0C:7D:E3:E0:EC:EF:07:5F:72:F6:
C1:A7:F8:5E:80:02:20:3E:4E:92:C1:25:FF:06:88:22:
DD:29:17:B5:90:EF:3E:35:CE:24:D5:EF:3E:B2:0F:8B:
F8:6D:DF:DB:B4:6C:7D
Version : v1 (0x0)
Log ID : DD:DC:CA:34:95:D7:E1:16:05:E7:95:32:FA:C7:9F:F8:
3D:1C:50:DF:DB:00:3A:14:12:76:0A:2C:AC:BB:C8:2A
Timestamp : Apr 8 13:03:46.857 2025 GMT
Extensions: none
30:45:02:20:2A:45:92:1D:C5:C1:0A:04:68:2D:87:FA:
4E:88:98:2A:A9:A2:A3:8D:5D:3C:5A:9B:23:AC:BA:5B:
A8:DF:4E:A6:02:21:00:8D:AC:52:A5:E1:F9:F1:29:8C:
A4:25:4F:E2:9E:86:B3:BB:32:07:6F:D1:4C:39:CC:5E:
16:72:37:33:3B:BD:6A
Signature Value:
60:f7:c4:0a:20:a9:c5:b3:7e:43:16:d1:d1:0c:b4:c1:b9:67:
ea:8c:07:6c:25:56:75:d2:22:1f:0f:d5:48:97:7b:c0:5f:ae:
5c:a5:21:7f:4a:a5:52:5f:af:ce:9c:f8:46:bc:40:ce:45:9a:
b4:62:f4:cf:d3:29:1e:29:0f:53:7d:70:d9:44:7a:2d:2a:27:
60:8d:9b:d4:49:ac:f4:33:db:f7:3a:89:72:07:58:6a:67:11:
57:a6:80:a5:dd:17:5b:9f:fb:9c:6d:85:0c:cb:68:26:58:fa:
d2:2c:ad:b9:69:2e:66:99:21:71:b0:10:30:74:9a:37:30:65:
fd:4b:40:8a:3b:0b:0b:1a:48:aa:c6:8d:d5:2d:08:5e:e8:2b:
60:bc:69:0b:c3:96:18:cd:ac:4e:80:05:51:86:5d:87:98:26:
b8:21:59:73:91:8e:53:93:f6:2c:6e:eb:c8:77:b8:2c:89:e4:
ef:74:9e:7e:7c:34:08:82:61:e1:b0:1d:15:8b:2d:b2:9e:b6:
18:ac:96:b2:ec:de:6f:f6:54:96:ca:f6:2b:32:85:e7:82:61:
3d:0a:c5:b6:4d:1f:03:46:80:92:d2:a0:99:50:e5:7c:ab:de:
1b:6a:aa:8e:8a:ba:bd:67:95:de:68:45:30:1f:ff:91:08:85:
c8:cd:20:a6
