Imagine your business requires a chat service, such as Mattermost (backed up by PostgreSQL), or a real-time data processing engine, such as Kapacitor (backed up by InfluxDB). To achieve this by hand would take you a lot of know-how, work, and time. Not so with Juju! In this tutorial you will learn how to achieve this in no time.
Contents:
- Create the test environment
- Install the Juju CLI client
- Get access to cloud infrastructure
- Connect your cloud to Juju
- Add your cloud credentials to Juju
- Install a Juju controller in your cloud
- Create a workspace on your cloud
- Deploy applications on your workspace
- Integrate your applications
- Test your deployment
- Destroy the test environment
- Next steps
The instructions in this tutorial are based on an Ubuntu system. This section details how to quickly create an Ubuntu test environment on MS Windows and macOS using Multipass. This section is also useful for those that are already running Ubuntu, but would like to create an isolated test environment that can be easily removed once this tutorial has been completed.
First, install Multipass.
Then, start a virtual machine with 8 GB RAM, 2 CPU cores, and 20 GB disk allocated to it, as shown below. We’ve called ours my-tiny-cloud
multipass launch -n my-tiny-cloud -m 8g -c 2 -d 20G
Multipass will confirm the creation:
Launched: my-tiny-cloud
At this point you will be able to enter a command-line with the shell
command:
multipass shell my-tiny-cloud
This will give you access to a shell (you may see a different prompt, depending on the version installed):
ubuntu@my-tiny-cloud:~$
You are now ready to follow the rest of this guide in our newly created Ubuntu machine. All commands should be typed in this shell.
If for whatever reason you need to interrupt this tutorial, we recommend running multipass stop my-tiny-cloud
to stop the instance. When you resume, run multipass start my-tiny-cloud
We will now install the Juju CLI client via snap
If the installation was successful, you will see a message similar to the one below:
juju 2.9.32 from Canonical✓ installed
Juju supports a wide range of clouds—public or private, Kubernetes or not. To keep things simple, in this tutorial we will require nothing more than your local workstation, where you can create Kubernetes / non-Kubernetes cloud infrastructure with MicroK8s / LXD.
Expand to see the instructions for MicroK8s
Execute the code below to install and configure MicroK8s:
# Install Microk8s from snap:
sudo snap install microk8s --classic --channel=1.24
# Add the 'ubuntu' user to the Microk8s group:
sudo usermod -a -G microk8s ubuntu
# Give the 'ubuntu' user permissions to read the ~/.kube directory:
sudo chown -f -R ubuntu ~/.kube
# Create the 'microk8s' group:
newgrp microk8s
# Enable the necessary Microk8s addons:
microk8s enable hostpath-storage dns
Expand to see the instructions for LXD
LXD should be already installed in your Ubuntu system. Execute the code below to configure it:
lxd init --auto
lxc network set lxdbr0 ipv6.address none
Juju recognizes your MicroK8s / LXD cloud infrastructure automatically. You can already see it if you run:
juju clouds
Expand to see the output for MicroK8s
microk8s 1 localhost k8s 1 built-in A Kubernetes Cluster
Expand to see the output for LXD
localhost 1 localhost lxd 1 built-in LXD Container Hypervisor
Note: In the juju clouds
output, the “Default” field stands for the default cloud region. This concept is relevant for public clouds. Here you can ignore the “localhost” value in that column.
For clouds where this step is not implicit, connecting the cloud to Juju is done via the juju add-cloud
command.
At this point what you have there is just cloud infrastructure, an empty cloud. There are no resources being used yet.
You don’t need to add any credentials for MicroK8s / LXD explicitly.
For clouds where this step is not implicit, see How to add a cloud credential to the Juju client.
The code below bootstraps a controller named tutorial-controller
into your cloud:
juju bootstrap <cloud name> tutorial-controller
Expand to see the code with the MicroK8s cloud name
juju bootstrap microk8s tutorial-controller
Expand to see the code with the LXD cloud name
juju bootstrap localhost tutorial-controller
The next step is to create a workspace on your cloud. We do this by creating a model, as shown below. We will name ours tutorial-model
juju add-model tutorial-model
We’ve got our workspace. Let’s start deploying applications. In Juju, that is done via small pieces of software called ‘Charmed Operators’, or ‘charms’. Charms act as translators between Juju and applications so that you can very easily perform any application operation you want. More concretely, if you want to deploy an application, all you have to do is:
juju deploy <charm name>
When you run this, Juju will pull the charm from Charmhub and then install the application on your cloud.
Small caveat: At present you need to choose between a Kubernetes and a non-Kubernetes charm version, depending on whether your cloud infrastructure is Kubernetes or not.
Expand to deploy Mattermost and PostgreSQL on MicroK8s
Let’s deploy Mattermost, an application that provides a chat service:
juju deploy mattermost-k8s
When deployed, this outputs:
Located charm "mattermost-k8s" in charm-store, revision 20
Deploying "mattermost-k8s" from charm-store charm "mattermost-k8s", revision 20 in channel stable
You can observe the deployment status with the following command:
watch -c juju status --format short --color
But Mattermost requires a database service. Let’s install PostgreSQL to provide this service:
juju deploy postgresql-k8s
Located charm "postgresql-k8s" in charm-store, revision 9
Deploying "postgresql" from charm-store charm "postgresql-k8s", revision 9 in channel stable
That’s it. Your applications are now deployed.
Expand to deploy Kapacitor and InfluxDB on LXD
Let’s deploy Kapacitor, an application that provides real time analytics:
juju deploy kapacitor
Located charm "kapacitor" in charm-hub, revision 1
Deploying "kapacitor" from charm-hub charm "kapacitor", revision 1 in channel stable on xenial
But Kapacitor requires a database service. Let’s install InfluxDB to provide this service:
juju deploy influxdb
Located charm "influxdb" in charm-hub, revision 24
Deploying "influxdb" from charm-hub charm "influxdb", revision 24 in channel stable on focal
We’ve deployed two applications that look like they need to work together. However, currently, they don’t. We need to integrate them. In Juju, integrating applications is a first class operation:
juju relate <application 1> <application 2>
Expand to relate Mattermost and PostgreSQL on MicroK8s
juju relate mattermost-k8s postgresql-k8s:db
You can again observe the deployment status with the following command:
That’s it. Your applications now know about each other and are ready to work together.
Expand to relate Kapacitor and InfluxDB on LXD
juju relate kapacitor influxdb
You’ve integrated your applications. You now have a functional working system. Time to try it out!
Expand to test your Mattermost deployment on MicroK8s
Execute the code below to get the IP address of your Mattermost pod:
microk8s kubectl get pods -n tutorial-model
Now, use the IP address as shown below to check that the application is running:
curl <IP address>/api/v4/system/ping
You should see the following:
{"AndroidLatestVersion":"","AndroidMinVersion":"","DesktopLatestVersion":"","DesktopMinVersion":"","IosLatestVersion":"","IosMinVersion":"","status":"OK"}
Congratulations, your Mattermost application is ready to use!
Expand to test your Kapacitor deployment on LXD
Execute the code below to get the IP address of your Kapacitor instance:
juju status
curl -G 'http://<IP address>/kapacitor/v1/ping'
| Code | Meaning |
| 204 | Success |
Congratulations, your Kapacitor application is ready to use!
Destroy your test environment
Once you are done, you can run the code below to stop and delete your Multipass test environment.
# Stop your instance
# Delete your instance permanently
multipass delete --purge my-tiny-cloud
You can also uninstall Multipass to remove any trace of this guide.
Next steps
This tutorial has introduced you to the basic things you can do with Juju. But there is a lot more to explore:
If you are wondering… | visit… |
“How do I…?” | Juju OLM How-to docs |
“What is…?” | Juju OLM Reference docs |
“Why…?”, “So what?” | Juju OLM Explanation docs |
