I am setting up a charmed distribution of OSM along with MicroStack, i.e., ./install_osm.sh --charmed --microstack and although the whole process completed successfully, MicroStack has not been added as a VIM.
My system is running Ubuntu 18.04.
I grepped for errors and could only find:
Error while executing command: ConflictException: 409, Security group rule already exists. Rule id is 65339638-dfd1-4ca5-96a9-74c06acc2342.
Another problem that would lead to MicroStack not being added as a VIM is the OSM_HOSTNAME not working with the xip.io DNS service (which I believe is down).
Thus, due OSM_HOSTNAME being non resolvable, any osm-client command will have failed, as we can see here:
curl https://cloud-images.ubuntu.com/focal/current/focal-server-cloudimg-amd64.img | microstack.openstack image create --public --container-format=bare --disk-format=qcow2 ubuntu20.04
(6, 'Could not resolve host: nbi.VM_IP.xip.io')
Maybe "--hostname" option or OSM_HOSTNAME environment variable needs to be specified
Your installation is now complete, follow these steps for configuring the osmclient:
1. Create the OSM_HOSTNAME environment variable with the NBI IP
export OSM_HOSTNAME=nbi.VM_IP.xip.io:443
2. Add the previous command to your .bashrc for other Shell sessions
echo "export OSM_HOSTNAME=nbi.VM_IP.xip.io:443" >> ~/.bashrc
Questions
Is this a known issue with xip.io?
I searched for what the installation script does for a charmed + microstack installation and I can see from the osm-devops repository, here that it doesnât use xip.io. Am I missing something with the installation script?
I downloaded it via wget https://osm-download.etsi.org/ftp/osm-9.0-nine/install_osm.sh.
Iâve tried the command youâve send me but got an error regarding MicroStack and the --auto flag.
juju status shows all services active, but sudo snap services microstack shows many of the core services, e.g. neutron-api disabled.
Hereâs the error output from the installation script
Trying to install osmclient from channel 9.0/stable
osmclient (9.0/stable) v9.1.1-dirty from OSM Support (osmsupport) installed
osmclient snap installed
39002d9a-a987-434d-950d-cd66365df912
28b43380-8e1f-4f60-982c-561be6bfb461
Warning: flag --classic ignored for strictly confined snap microstack
microstack (beta) ussuri from Canonicalâ installed
File "/snap/microstack/233/bin/microstack_init", line 11, in <module>
load_entry_point('microstack-init==0.0.1', 'console_scripts', 'microstack_init')()
File "/snap/microstack/233/lib/python3.8/site-packages/init/main.py", line 60, in wrapper
return func(*args, **kwargs)
File "/snap/microstack/233/lib/python3.8/site-packages/init/main.py", line 169, in init
auto = process_init_args(args)
File "/snap/microstack/233/lib/python3.8/site-packages/init/main.py", line 126, in process_init_args
raise ValueError('A role (--compute or --control) must be specified '
ValueError: A role (--compute or --control) must be specified when using --auto
Due to the output above, I believe microstack --init wasnât run.
Additionally, I presume here are the commands the installation script runs to setup MicroStack networking and add it as a VIM.
I presume we can use these commands to setup an externally instantiated instance of MicroStack
@davigar15 sorry for bugging you again, but I just figured out from the error above that the osm-devops package installed does not contain the updated version of the charmed_install.sh script
I am also getting this error while triggering installation script with --charmed flag
cmd: ./install_osm.sh --charmed
error: permanently dropping privs did not work: File exists
Microk8s storage failed to enable
Thanks for the installation guide!,
I have encountered the following problem at the end of the installation:
14 / 14 services active
OSM with charms deployed
Trying to install osmclient from channel 10.0/stable
Se ha instalado osmclient (10.0/stable) v10.0.1-0-g42e87fa por OSM Support (osmsupport)
ERROR: Error 404: <html>
<head><title>404 Not Found</title></head>
<body>
<center><h1>404 Not Found</h1></center>
<hr><center>nginx/1.19.0</center>
</body>
</html>
<body>
</body>
</html>
export OSM_HOSTNAME=nbi.192.168.68.105.nip.io:443
echo "export OSM_HOSTNAME=nbi.192.168.68.105.nip.io:443" >> ~/.bashrc
DONE
After creating the variables appears the following issue:
osm version
<body>
</body>
</html>
Iâm getting the same error as mentioned here along with an ValueError: A role (--compute or --control) must be specified when using --auto error regarding microstack initialization proccess, when trying to install OSM along with microstack using the command : ./install_osm.sh --charmed --microstack .
When I run the command: microk8s.kubectl -n osm describe ingress,
I get in the default backend default-http-backend:80 (<error: endpoints "default-http-backend" not found>)
There is no connection with the NBI. How can I fix this. Thank you.
Hello @davigar15, I am having the same issue as described by @virs. I tried the fix that you identified but it didnât work, Iâm still having the 404 errors when trying to use osm commands.
This is clearly an issue with version 10, I installed version 9 and everything works correctly. Looks like the ingress is not routing correctly the requests or does not have a correct route to the service hence falling in the default backend and given that this one is not defined as you can see in my previous post, it throws a 404 error.
