Welcome to Charmed OSM
The objective of this page is to give an overview of the first steps to get started with Charmed OSM.
Requirements
- OS: Ubuntu 18.04 LTS (Bionic) or Ubuntu 20.04 LTS (Focal)
- MINIMUM:
- 4 CPUs
- 8 GB RAM
- 50GB disk
- Single interface with Internet access.
- RECOMMENDED:
- 8 CPUs
- 16 GB RAM
- 120GB disk
User Guide
Installing OSM has never been easier. With one command, you will be able to deploy Charmed OSM in an empty environment using microk8s.
First of all, letâs download the installation script for upstream, and give it executable permissions.
wget https://osm-download.etsi.org/ftp/osm-11.0-eleven/install_osm.sh
chmod +x install_osm.sh
Install
To install Charmed OSM locally you should execute the following command:
./install_osm.sh --charmed
Checking the status
While the installer is running, you will see progress in the number of active services, which can take several minutes depending on the internet connection speed. While this is running, to see the status of the deployment execute watch -c juju status --color. Also, you can execute watch kubectl -n osm get pods to see the status of the Kubernetes Pods.
You will see this output from the juju status command when the deployment is finished.
$ juju status
osm osm-vca microk8s/localhost 2.9.17 unsupported 14:32:14+01:00
App Version Status Scale Charm Store Channel Rev OS Address Message
grafana ubuntu/grafana@8952155 active 1 grafana charmstore edge 10 kubernetes 10.152.183.111
kafka wurstmeister/kafka@968e579 active 1 kafka charmstore edge 1 kubernetes 10.152.183.203
keystone opensourcemano/keystone:11 active 1 keystone charmstore edge 16 kubernetes 10.152.183.103
lcm opensourcemano/lcm:11 active 1 lcm charmstore edge 15 kubernetes 10.152.183.211
mariadb-k8s mariadb/server:10.3 active 1 mariadb-k8s charmstore stable 35 kubernetes 10.152.183.246
mon opensourcemano/mon:11 active 1 mon charmstore edge 12 kubernetes 10.152.183.249
mongodb library/mongo@11b4907 active 1 mongodb-k8s charmhub stable 1 kubernetes 10.152.183.122
nbi opensourcemano/nbi:11 active 1 nbi charmstore edge 18 kubernetes 10.152.183.217
ng-ui opensourcemano/ng-ui:11 active 1 ng-ui charmstore edge 25 kubernetes 10.152.183.108
pla opensourcemano/pla:11 active 1 pla charmstore edge 13 kubernetes 10.152.183.83
pol opensourcemano/pol:11 active 1 pol charmstore edge 10 kubernetes 10.152.183.181
prometheus .../prometheus-backup@f3ddf1f active 1 prometheus charmstore edge 9 kubernetes 10.152.183.53
ro opensourcemano/ro:11 active 1 ro charmstore edge 10 kubernetes 10.152.183.84
zookeeper .../kubernetes-zookeeper@35... active 1 zookeeper charmstore edge 1 kubernetes 10.152.183.235
grafana/0* active idle 10.1.245.122 3000/TCP ready
kafka/0* active idle 10.1.245.115 9092/TCP ready
keystone/0* active idle 10.1.245.119 5000/TCP ready
lcm/0* active idle 10.1.245.86 9999/TCP ready
mariadb-k8s/0* active idle 10.1.245.107 3306/TCP ready
mon/1* active idle 10.1.245.83 8000/TCP ready
mongodb/0* active idle 10.1.245.124 27017/TCP
nbi/0* active idle 10.1.245.105 9999/TCP ready
ng-ui/0* active idle 10.1.245.98 80/TCP ready
pla/0* active idle 10.1.245.75 9999/TCP ready
pol/0* active idle 10.1.245.68 9999/TCP ready
prometheus/0* active idle 10.1.245.79 9090/TCP ready
ro/0* active idle 10.1.245.104 9090/TCP ready
zookeeper/0* active idle 10.1.245.84 2181/TCP,2888/TCP,3888/TCP ready
Known issues
None.
Start playing with OSM
If you have installed OSM in an external machine, or in a VM, you can access it through the kubernetes ingress controller enabled in microk8s. These are the services exposed:
- OSM UI: https://ui.<ip>.nip.io
- NBI: https://nbi.<ip>.nip.io
- Prometheus: https://prometheus.<ip>.nip.io
- Grafana: https://grafana.<ip>.nip.io
Note: <ip> should be replaced by the IP of the default network interface in your OSM Machine
OSM User Interface
Access from outside the machine at http://ui.<ip>.nip.io, or at http://10.152.183.108 (see ng-ui cluster IP in juju status) from inside the OSM Machine.
- Username: admin
- Password: admin
OSM Client
The OSM client is automatically installed with Charmed OSM, but if you want to install it in a separate machine, you can easily do that installing the osmclient snap:
sudo snap install osmclient --channel 11.0/stable
The OSM client needs the OSM_HOSTNAME environment variable pointing to the NBI.
export OSM_HOSTNAME=nbi.<ip>.nip.io:443
osm --help # print all the commands
Prometheus
Access Prometheus User Interface from outside the machine at http://prometheus.<ip>.nip.io, or at http://10.152.183.53:9090 (see prometheus cluster IP in juju status) from inside the OSM Machine.
- Username: admin
- Password: admin
Grafana
Access Grafana User Interface from outside the machine at http://grafana.<ip>.nip.io, or at http://10.152.183.111:3000 (see grafana cluster IP in juju status) from inside the OSM Machine.
- Username: admin
- Password: Execute this command to get the password:
juju run --unit grafana/0 -- "echo \$GF_SECURITY_ADMIN_PASSWORD".
Uninstall
To uninstall Charmed OSM you should execute the following command.
juju kill-controller osm-vca -y -t0
Note: this will not remove microk8s or juju even if they were installed by the installer. Removal of these components can be done manually once it is known that no other services require them with the following commands:
sudo snap remove --purge juju
sudo snap remove --purge microk8s
Troubleshooting
If you have any trouble with the installation, please contact us, we will be glad to answer your questions:
- Guillermo Calviño guillermo.calvino@canonical.com
- David Garcia david.garcia@canonical.com
- Eduardo Sousa eduardo.sousa@canonical.com
- Mark Beierl mark.beierl@canonical.com
