Warning: Very early draft
Adding a private Docker registry is essential for enterprises wishing to maintain control of hosting their proprietary software while utilising container technology.
Reasons why you might want to deploy a private Docker registry:
- speed up deployments by hosting popular images within your own infrastructure
- use Docker-enabled technologies, such as Kubernetes from, within an air-gapped hosting environment
- increase resilience by not needing to rely on the global public registry
- increase security by reducing the likelihood of sidechannel attacks by only allowing whitelisting images to be installed by your teams
The tool that we’ll be using for this tutorial is Juju. To install Juju, visit Getting Started with Juju.
What is Juju?: Juju is devops software. It’s the easiest way to deploy, configure and maintain workloads in containers, VMs and bare metal.
Deploy a Docker registry with 4 commands
On a command line prompt:
Command 1: Deploy the registry
The deploy command accesses the Juju charm store. I
Command to run:
juju deploy ~containers/docker-registry
Output:
Located charm "cs:~containers/docker-registry-152".
Deploying charm "cs:~containers/docker-registry-152"
Commands 2 and 3: Add relations
hello: This fd
If you have also installed the charmed-kubernetes or kubernetes-core bundles, then the process
juju expose docker-registry
Dockerfile
FROM ubuntu:18.04
LABEL \
description="Example Dockerfile used for illustrating deploying a private Docker registry with Juju" \
maintainer="tsm@canonical.com" \
vendor="Canonical"
ENV APACHE_RUN_USER www-data
ENV APACHE_RUN_GROUP www-data
ENV APACHE_LOG_DIR /var/log/apache2
ENV APACHE_PID_FILE=/var/run/apache2/apache2$SUFFIX.pid
ENV APACHE_LOCK_DIR=/var/lock/apache2
VOLUME /var/www/html
RUN apt-get update
RUN apt-get install -y apache2
RUN mkdir -p $APACHE_RUN_DIR $APACHE_LOCK_DIR $APACHE_LOG_DIR
EXPOSE 80
CMD ["apache2","-DFOREGROUND"]
docker build -t httpd:testing .
View status
$ juju status
docker bos canonistack/canonistack-bos01 2.7-beta1.1 unsupported 15:56:25+13:00
docker-registry active 1 docker-registry jujucharms 152 ubuntu exposed
easyrsa 3.0.1 active 1 easyrsa jujucharms 277 ubuntu
docker-registry/0* active idle 0 10.48.131.236 5000/tcp Ready at 10.48.131.236:5000 (https).
easyrsa/0* active idle 1 10.48.130.170 Certificate Authority connected.
0 started 10.48.131.236 f74afe5f-a8f2-4d68-8c3c-dcd5bfcf45be bionic nova ACTIVE
1 started 10.48.130.170 2bdc56d9-1820-4004-8750-99379c11a9fb bionic nova ACTIVE
Use variables to make things easier
export IP=`juju run --unit docker-registry/0 'network-get website --ingress-address'`
export PORT=`juju config docker-registry registry-port`
export REGISTRY=$IP:$PORT
Optional: Set basic auth password
juju config docker-registry auth-basic-password=password
Fetch IP address
upload a docker image to the custom registry
docker tag httpd:testing 10.48.131.236:5000/httpd:testing
We can verify that the self-hosted Docker repository has been tagged correctly.
docker images
REPOSITORY TAG IMAGE ID CREATED SIZE
10.48.131.236:5000/ubuntu http c89514e93594 2 minutes ago 188MB
Because we use a self-signed certificate, pushing the image fails by default:
docker push 10.48.131.236:5000/ubuntu:http
The push refers to repository [10.48.131.236:5000/ubuntu]
Get https://10.48.131.236:5000/v2/: x509: certificate signed by unknown authority
We need to extract the CA cert file that our locally hosted Certificate Authority created. Oh yeah, by the way, we also installed a Certificate Authority to ensure that all communication with our private Docker registry occurs over TLS.
juju config docker-registry tls-ca-path
/etc/docker/registry/ca.crt
To extract it, Juju has a built-in SCP helper for working with machines. Machine 0 hosts the docker-registry/0 unit.
SCP the ca.cert file to the current working directory.
# juju scp 0:/usr/local/share/ca-certificates/juju-docker-registry.crt ```
juju scp 0:/etc/docker/registry/ca.crt ./
sudo chown root ca.crt
sudo chgrp root ca.crt
Move it its new home
Create a new certs.d directory
When using snap:
sudo mkdir -p /var/snap/docker/common/etc/certs.d/$REGISTRY
sudo mv ca.crt /var/snap/docker/common/etc/certs.d/$REGISTRY/ca.crt
Standard docker
Restart
sudo snap restart docker
or
sudo systemctl restart docker.service
