This guide introduces you to Juju on MS Windows, macOS and Linux. You’ll be deploying a simple web application to your local machine. Later on, you’ll be able to use those same commands to deploy the app into the cloud, whether private or public.
Watch this guide
Would you prefer to watch, rather than type? This recording goes through the entire tutorial:
Setting up
You need to install snap, which will allow you to install other software used in this tutorial (and cleanly remove things later if desired).
The instructions in this tutorial are based on an Ubuntu system. We’ve provided instructions for getting access to Ubuntu quickly for those readers that require it.
Instructions for MS Windows and macOS
We recommend using an isolated environment for testing.
Install Multipass
If you’re not running Ubuntu, visit multipass.run to install Multipass. Multipass is a tool for quickly running virtual machines from any host operating system. This will allow you to create a fully-isolated test environment that won’t impact your host system.
Multipass provides a command line interface to launch, manage and generally fiddle about with instances of Linux. The downloading of a minty-fresh image takes a matter of seconds, and within minutes a VM can be up and running.
— The Register
Create virtual machine
We want to be able to experiment with Juju and evaluate it without the testing impacting on the rest of our system. To enter a shell within a virtual machine microcloud
that has 8 GB RAM allocated to it, execute this command:
$ multipass launch -n microcloud -m 8g -c 2 -d 20G
Launched: microcloud
Once multipass
has downloaded the latest Long Term Support version of the Ubuntu operating system, you will be able to enter a command-line shell:
$ multipass shell microcloud
multipass@microcloud:~$
Need to install snap?
Visit the snapcraft homepage for installation instructions. Snap makes software installation trivial and secure.
Install Juju
Install Juju locally with snap:
$ sudo snap install juju --classic
juju 2.6.8 from Canonical✓ installed
Create a cloud on localhost
LXD manages operating system containers and makes the the “localhost” cloud available to Juju.
LXD is a next generation system container manager. It offers a user experience similar to virtual machines but using Linux containers instead.
It’s image based with pre-made images available for a wide number of Linux distributions
and is built around a very powerful, yet pretty simple, REST API.
Ensure LXD is installed
Install LXD with snap:
$ sudo snap install lxd
lxd 3.17 from Canonical✓ installed
If LXD is already installed, you’ll receive this warning:
snap "lxd" is already installed, see 'snap help refresh'
Configure LXD
LXD needs to be configured for its environment:
$ lxd init --auto
If you omit the --auto
option, you can tailor your LXD installation. Use lxd help init
for a list of all the options.
Verify that the localhost cloud is available
Our localhost
cloud is now established. We can verify that by running juju clouds
. Juju should have detected the presence of LXD and has added it as the localhost
cloud.
$ juju clouds
localhost 1 localhost lxd LXD Container Hypervisor
Bootstrap the controller
Juju uses an active software agent, called the controller, to manage applications. The controller is installed on a machine through the bootstrap process.
During the bootstrap process, Juju connects with the cloud, then provision a machine to install the controller on, then install it.
$ juju bootstrap localhost overlord
Creating Juju controller "overlord" on localhost/localhost
Looking for packaged Juju agent version 2.6.8 for amd64
Accessing help:
The juju bootstrap
command takes several parameters. Use juju help bootstrap
to review them.
First workload: Hello Juju!
The first workload that you’ll deploy is a simple web application. You’ll deploy an application that uses the Flask microframework to send “Hello Juju!” via HTTP.
$ juju deploy hello-juju
Located charm "cs:hello-juju-4".
Deploying charm "cs:hello-juju-4".
The charm name hello-juju
is resolved into an actual charm version by contacting the Charm Store. This charm is then downloaded by the controller and used as the source of the application that was created with the same name.
Checking the deployment
Now that a workload is in place, use juju status
to inspect what is happening:
$ juju status
default overlord localhost/localhost 2.6.8 unsupported 16:24:04+12:00
hello-juju active 1 hello-juju jujucharms 4 ubuntu
hello-juju/0* active idle 0 10.47.112.215 80/tcp
0 started 10.47.112.215 juju-646ac9-0 bionic Running
Connecting to the application
The juju status
output above provided the “Public address” of the hello-juju/0
unit as 10.47.112.215
and its Ports column as 80/tcp
. Let’s connect!
$ curl 10.47.112.215
Hello Juju!
Connection refused?
On non-localhost clouds, the connection may be refused. This is normal. To configure the necessary security groups and firewall rules, use juju expose
juju expose hello-juju
Access a secure shell
Juju provides some useful functionality for SREs and operations teams who need to interact with units and machines out of the box.
The ssh
command accepts unit (and machine) names. They will be substituted for the relevant IP address.
Access the machine via the unit name:
$ juju ssh hello-juju/0
ubuntu@juju-646ac9-0:~$
Or via the machine ID:
$ juju ssh 0
Once you’ve connected, you can access the hello-juju
web server:
$ curl localhost
Hello Juju!
Relating another application: adding PostgreSQL to the deployment
Relations are Juju’s defining concept and its main point of difference with other systems in its class. They enable the simplicity, security and stability offered by the whole project.
The hello-juju
web server maintains a count for each greeting that it has sent out via the /greetings
endpoint.
$ curl 10.47.112.215/greetings
{"greetings": 2}
By default, this state is maintained within a SQLite database that is set up by the hello-juju
charm itself. To move to PostgreSQL as the data store, two commands are required:
$ juju deploy postgresql
Located charm "cs:postgresql-199".
Deploying charm "cs:postgresql-199".
$ juju relate postgresql:db hello-juju
About relations and how they work
hello-juju
includes support for the pgsql
relation, which is provided by the postgresql
charm and others that present the same interface, such as pg_bouncer
Relations are protocols that enable applications to auto-configure themselves. In the case of pgsql
, the requiring charm (hello-juju
) requests that a database be created on its behalf and the provider charm (postgresql
) carries that step out and also creates the user account. The postgresql
then sends the connection details back to hello-juju
The data sent between charms is facilitated by the Juju controller. The Juju controller establishes a certificate authority and ensures that all data transported is fully encrypted. Relations prevent secrets from being stored insecurely because they’re not needed by application developers.
What relations are not
Relations are not a networking construct, such as a tunnel between two applications. Instead, they’re a data sharing protocol defined for charm to charm negotiation. As charms are executed by Juju agents, data is shared between agent to agent.
Re-checking the deployment status
Now that the new application and a relation are in place, the juju status
output has expanded. Add the --relations
option include relations infomation.
$ juju status --relations
hello-juju active 1 hello-juju jujucharms 3 ubuntu
postgresql 10.10 active 1 postgresql jujucharms 199 ubuntu
postgresql/0* active idle 0 10.47.112.216 5432/tcp Live master (10.10)
1 started 10.47.112.216 juju-646ac9-1 bionic Running
postgresql:coordinator postgresql:coordinator coordinator peer
postgresql:db hello-juju:db pgsql regular
postgresql:replication postgresql:replication pgpeer peer
Next steps
- You can scale out to a public cloud with JAAS, the hosted controller service
- Learn about all of the clouds that Juju supports
