[Draft] Charm hooks
About
Charm hooks are the mechanism that Juju uses to invoke charms. They are executable files within a charm’s hooks/ directory that are triggered by events.
Somewhat confusingly for newcomers to Juju though, most charms writers do not interact with hooks directly. Instead, the author of a charm interacts with an interface provided by a charming framework.
Triggers
The events that trigger hooks, and sequences of hooks, are useful to know:
Periodic Events
Timers trigger hooks:
Hook Comments
update-status Timer interval defined by the update-status-hook-interval model configuration option
collect-metrics This timer is not configurable.
Deployment and Unit Creation
When a charm is first deployed, via juju deploy, juju add-unit, or juju scale-application, the charm receives an opportunity to install any necessary software.
Kubernetes (K8s) Clouds
Hook Comments
*-relation-created For every peer relation
*-relation-created For other relations
leader-elected
config-changed
start
storage-attached
update-status
Traditional Clouds
Traditional clouds differ from K8s in that they include an install hook and their storage-attached hook occurs sooner (to enable installation to proceed on a persistent storage).
Hook Comments
storage-attached
install
leader-elected
config-changed
start
update-status
Machine Boot
When the underlying machine starts up, units hosted by the machine run the following hooks:
Kubernetes Clouds
No hooks are executed. The OCI image deployed by the charm includes an entrypoint itself.
Traditional Clouds
Hook Comments
start Prior to Juju 2.8, this was only triggered on first boot
Machine Shutdown
When the underlying machine reboots or is powered off, units hosted by the machine run the following hooks:
Kubernetes Clouds
Traditional Clouds
Hook Comments
stop Prior to Juju 2.8, no hooks were triggered
Configuration Change
When a Juju user executes juju config and changes an option, charms are notified of the change via a hook:
Hook Comments
config-changed
Unit Creation
See Deployment and Unit Creation.
Unit Removal
Units can be removed from a model at any time. Commands that invoke unit removal include juju remove-unit, juju remove-application, and juju scale-application.
Traditional Clouds
Units may be co-hosted on the same machine. These hooks provide the opportunity for units to clean up.
Hook Comments
*-storage-detached When the --destroy-storage option is provided
*-relation-departed For every relation that has moved past “created” into the “joined” state
stop
remove
Relation Creation
Relations invoke hooks within units of both applications, but neither application requires units on the other side to proceed. This can create an unintuitive situation where one unit can send data over the relation to units that have not yet been provisioned.
Hook Comments
<relation-name>-relation-created Does not imply that a unit is available on the other side of the relation.
Unit joins the relation
When a unit is added to a relation, all units are notified.
Hook Comments
<relation-name>-relation-joined
Change to Relation Data
When a unit executes the relation-set hook tool, all other units receive a notification:
Hook Comments
<relation-name>-relation-changed
Unit Departure from a Relation
When a unit is removed from the model, its related units are notified of this:
Hook Comments
<relation-name>-relation-departed
Relation Removal
When juju remove-relation or a command that removes relation, such as juju remove-application, is executed, units are notified:
Hook Comments
<relation-name>-relation-broken
Storage Creation
Storage is added (“attached”) to specific units, rather than to the application as a whole. The juju attach-storage command triggers the following hook once the cloud has made the storage volume available:
Hook Comments
<storage-name>-storage-attached
Storage Removed
Storage can be detached from a model via the juju detach-storage or removed altogether via juju destroy-storage. From the perspective of units, these two operations are indistinguishable and receive the same hook:
Hook Comments
<storage-name>-storage-detached
Series Upgrade
Machines are sometimes kept alive for many years. To support this use case, charms can manage the process of enabling an application to continue to function under a new operating system version.
Not applicable.
Traditional Clouds
Hook Comments
pre-series-upgrade Before the machine’s OS has been upgraded.
post-series-upgrade Once the machine’s OS has been upgraded.
Execution environment
Hooks are run in serial on each machine. When multiple units occupy the same machine, they can compete for execution time.
When multiple hooks are queued for execution, they operate in the following priority:
  • Upgrade Series hooks
    • pre-series-upgrade
    • post-series-upgrade
  • upgrade-juju
  • restart
  • Any hook that needs to be retried
  • Leadership hooks, e.g.
    • leader-elected
  • Actions hooks
  • Commands to be executed from juju run
  • Storage, e.g.
    • storage-attached
    • storage-detaching
  • Other hooks, except
  • update-status
Further Detail
An application unit’s direct action is entirely defined by its charm’s hooks. Hooks are executable files in a charm’s hooks directory; hooks with particular names (see below) will be invoked by the juju unit agent at particular times, and thereby cause changes to the world.
Whenever a hook-worthy event takes place, the unit agent first checks whether that hook is being debugged, and if so hands over control to the user. Otherwise, it tries to find a hook with precisely the right name. If the hook doesn’t exist, the agent continues without complaint; if the hook does exist, it is invoked without arguments in a specific hook context, and its output is written to the unit agent’s log. If it returns a non-zero exit code, the agent enters an error state and awaits user intervention.
The agent will also enter an error state if the unit agent process is aborted during hook execution.
There are multiple types of hooks, each described in more detail in the following sections.
None of the hooks are required; if you don’t implement a hook, it just doesn’t get run. When a hook event occurs, Juju will look for the corresponding hook file to execute, but if it finds none, will continue running without generating an error.
All the hooks must be written to be idempotent, meaning that there should be no difference from running the hook once from running it multiple times. This property is important because hooks can be run multiple times by the Juju system in ways that might be difficult to predict.
Events that trigger charm hooks
Many events
Machine startup
When the machine that’s hosting a Juju unit starts up, the start hook is executed. This hook may be necessary to perform some tasks
Machine shutdown
Shutting down a machine does not trigger any charm hooks to be fired.
New peer unit
Peer unit
Leader elected
Configuration changes via juju config and relation data
Charms are expected to respond appropriately as configuration changes . Many events can
  • The relation-set allows peers a
  • leader-set hook tool
Trigger Hook(s)
juju config
  • config-changed
  • juju relate <a> <b> On all units of application a:
  • config-changed
  • <rel>-relation-created
  • <rel>-relation-joined
    On all units of application b:
  • config-changed
  • config-changed
    • when users execute juju config, the config-change
    • a unit leaving may trigger a change in leadership
    Core lifecycle hooks
    These run during the normal charm lifecycle.
    config-changed
    config-changed runs in several different situations.
    • immediately after “install”
    • immediately after “upgrade-charm”
    • at least once when the unit agent is restarted (but, if the unit is in an error state, it won’t be run until after the error state is cleared).
    • after changing charm configuration using the GUI or command line interface
    It cannot assume that the software has already been started; it should not start stopped software, but should (if appropriate) restart running software to take configuration changes into account.
    install
    install is run at the beginning of a charm lifecycle. The hook should be used to perform one-time setup operations, such as installing prerequisite software that will not change with configuration changes.
    leader-elected
    leader-elected is run at least once to signify that Juju decided this unit is the leader. Authors can use this hook to take action if their protocols for leadership, consensus, raft, or quorum require one unit to assert leadership. If the election process is done internally to the application, other code should be used to signal the leader to Juju. For more information read the Implementing leadership page.
    leader-settings-changed
    leader-settings-changed runs when the leader has set values for the other units to respond to. Much like (config-changed)[#heading–config-changed] but for the leaders to send values to other units. Follower units can implement this hook and take action when the leader sets values. For more information read the Implementing leadership page.
    start
    start runs immediately after the first config-changed hook. It should be used to ensure the charm’s software is running. Note that the charm’s software should be configured so as to persist through reboots without further intervention on juju’s part.
    start is also run after a machine reboot.
    stop
    stop runs immediately before the end of the unit’s destruction sequence. It should be used to ensure that the charm’s software is not running, and will not start again on reboot.
    remove
    remove runs immediately after the stop hook.
    This hook is called when an application removal is requested by the client. It should implement the following logic:
    • Stop the application
    • Remove any files/configuration created during the application lifecycle
    • Prepare any backup(s) of the application that are required for restore purposes.
    upgrade-charm
    upgrade-charm runs immediately after any upgrade operation that does not itself interrupt an existing error state. It should be used to reconcile local state written by some other version of the charm into whatever form it needs to take to be manipulated by the current version.
    While the forced upgrade functionality is intended as a developer tool, and is not generally suitable for end users, it’s somewhat optimistic to depend on the functionality never being abused. In light of this, if you need to run an upgrade-charm hook before your other hooks will work correctly, it may be wise to preface all your other hooks with a quick call to your (idempotent) upgrade-charm.
    update-status
    update-status provides constant feedback to the user about the status of the application the charm is modeling. The charm is run by Juju at regular intervals, and gives authors an opportunity to run code that gets the “health” of the application.
    Relation hooks
    Units will only participate in relations after they’re been started, and before they’ve been stopped. Within that time window, the unit may participate in several different relations at a time, including multiple relations with the same name.
    To illustrate, consider a database application that will be used by multiple client applications. Units of a single client application will surely want to connect to, and use, the same database; but if units of another client application were to use that same database, the consequences could be catastrophic for all concerned.
    If juju respected the limit field in relation metadata, it would be possible to work around this, but it’s not a high- priority bug: most provider applications should be able to handle multiple requirers anyway; and most requirers will only be connected to one provider anyway.
    When a unit running a given charm participates in a given relation, it runs at least three hooks for every remote unit it becomes aware of in that relation.
    [name]-relation-created
    [name]-relation-created is run after the install hook and before any [name]-relation-joined hooks. It is guaranteed to run before any leadership hook for peer relations. For non-peer relations established at a later point in time, the hook will fire once the relation has been established.
    [name]-relation-joined is run only when that remote unit is first observed by the unit. It should be used to relation-set any local unit settings that can be determined using no more than the name of the joining unit and the remote private-address setting, which is always available when the relation is created and is by convention not deleted.
    You should not depend upon any other relation settings in the -joined hook because they’re not guaranteed to be present; if you need more information you should wait for a -changed hook that presents the right information.
    [name]-relation-changed
    [name]-relation-changed is always run once, after -joined, and will subsequently be run whenever that remote unit changes its settings for the relation. It should be the only hook that relies upon remote relation settings from relation-get, and it should not error if the settings are incomplete: you can guarantee that when the remote unit changes its settings, the hook will be run again.
    The settings that you can get, and that you should set, are determined by the relation’s interface.
    [name]-relation-departed
    [name]-relation-departed is run once only, when the remote unit is known to be leaving the relation; it will only run once at least one -changed has been run, and after -departed has run, no further -changed hooks will be run. This should be used to remove all references to the remote unit, because there’s no guarantee that it’s still part of the system; it’s perfectly probable (although not guaranteed) that the system running that unit has already shut down.
    When a unit’s own participation in a relation is known to be ending, the unit agent continues to uphold the ordering guarantees above; but within those constraints, it will run the fewest possible hooks to notify the charm of the departure of each individual remote unit.
    Once all necessary -departed hooks have been run for such a relation, the unit agent will run the final relation hook:
    [name]-relation-broken
    [name]-relation-broken indicates that the current relation is no longer valid, and that the charm’s software must be configured as though the relation had never existed. It will only be called after every necessary -departed hook has been run; if it’s being executed, you can be sure that no remote units are currently known locally.
    It is important to note that the -broken hook might run even if no other units have ever joined the relation. This is not a bug: even if no remote units have ever joined, the fact of the unit’s participation can be detected in other hooks via the relation-ids tool, and the -broken hook needs to execute to give the charm an opportunity to clean up any optimistically-generated configuration.
    And, again, it’s important to internalise the fact that there may be multiple runtime relations in play with the same name, and that they’re independent: one -broken hook does not mean that every such relation is broken.
    Storage Charm Hooks
    Juju can provide a variety of storage to charms. The charms can define several different types of storage that are allocated from Juju. To read more information, see the storage document
    [name]-storage-attached
    [name]-storage-attached allows the charm to run code when storage has been added. The storage-attached hooks will be run before the install hook, so that the installation routine may use the storage. The name prefix of this hook will depend on the storage key defined in the metadata.yaml file.
    [name]-storage-detaching
    [name]-storage-detaching allows the charm to run code before storage is removed. The storage-detaching hooks will be run before storage is detached, and always before the stop hook is run, to allow the charm to gracefully release resources before they are removed and before the unit terminates. The name prefix of the hook will depend on the storage key defined in the metadata.yaml file.
    Metric Hooks
    collect-metrics
    Juju executes the collect-metrics hook every five minutes for the lifetime of the unit. Use the add-metric hook tool in collect-metrics to add measurements to Juju.
    Because it may run concurrently with lifecycle charm hooks, collect-metrics executes in a more restricted environment where many hook tools (such as config-get) are not available. If access to charm configuration or other items is absolutely required, charmhelpers.core.unitdata.kv may be used to pass information into the collect-metrics hook context.
    Writing hooks
    If you follow the Getting started guide, you’ll get a good sense of the basics. To fill out your knowledge, you’ll want to study the hook context and tools, and to experiment with debug-hooks.
    Independent of the nuts and bolts, though, good hooks display a number of useful high-level properties:
    • They are idempotent: that is to say that there should be no observable difference between running a hook once, and running it N times in a row. If this property does not hold, you are likely to be making your own life unnecessarily difficult: apart from anything else, the average user’s most likely first response to a failed hook will be to try to run it again (if they don’t just skip it).
    • They are easy to read and understand. It’s tempting to write a single file that does everything, and which just calls different functions internally depending on the value of argv[0], and to symlink that one file for every hook; but such structures quickly become unwieldy. The time taken to write a library, separate from the hooks, is very likely to be well spent: it lets you write single hooks that are clear and focused, and insulates the maintainer from irrelevant details.
    • Where possible, they reuse common code already written to ease or solve common use cases.
    • They do not return errors unless there is a good reason to believe that they cannot be resolved without user intervention. Doing so is an admission of defeat: a user who sees your charm returning an error state is unlikely to have the specific expertise necessary to resolve it. If you have to return an error, please be sure to at least write any context you can to the log before you do so.
    • They write only very sparingly to the charm directory.
    We recommend you also familiarise yourself with the best practices and, if you plan to distribute your charm, the charm store policy.
    These changes are for juju 2.8.
    • Added additional data to the start hook
    • A new section for new relation-created hook.
    • Split the stop hook into stop and a new remove hook.
    This document will supersede the original when Juju 2.8 is released.
    I would not recommend this tutorial really. It’s introducing the new charmer to the reactive framework before even having written a first basic hooks charm. It is a very tough start. There must be a much simpler tutorial to get started.
    Good point. It’s quite complex for new people. I will be updating the getting started guides for charming over the next few weeks :slight_smile:
    @hmlanigan
    I’m not sure who to address really about this
    “#TODO: This hook lacks official documentation”
