This document serves to record the policies around charms and bundles included in the charm store, and the management of said collection. Charms and bundles in the store are peer-reviewed by the community and are considered ready for production grade consumption. These charms are marked as reviewed in the GUI and must follow these quality guidelines in ordered to be considered for the Store, otherwise they can live in personal name spaces.
These guidelines include things the charm/bundle MUST do, requirements that will return an ERROR if not properly followed are listed first in each section. The guidelines also include things charm/bundle SHOULD do, strong recommendations that are not hard requirements but which will return a WARNING if not properly followed are listed second in each section.
General guidelines
Not following these guidelines will result in an ERROR (E:) in charm test
- Must follow the spirit of the Ubuntu Philosophy.
- Must serve a useful purpose and have well defined behaviour.
- Must also be valid for the charm and/or bundle format defined in Juju’s documentation.
- Must verify that any software installed or utilized is verified as coming from the intended source.
- Any software installed from the Ubuntu or CentOS default archives satisfies this due to the apt and yum sources including cryptographic signing information.
- Third party repositories must be listed as a configuration option that can be overridden by the user and not hard coded in the charm itself.
- Launchpad PPAs are acceptable as the
add-apt-repository
command retrieves the keys securely. - Other third party repositories are acceptable if the signing key is embedded in the charm.
- Must provide a means to protect users from known security vulnerabilities in a way consistent with best practices as defined by either operating system policies or upstream documentation. Basically, this means there must be instructions on how to apply updates if you use software not from distribution channels.
- Must have hooks that are idempotent.
Not following these guidelines will result in a WARNING (W:) in `charm test`:
- Should be built using charm layers.
- Should be delivered using Juju Resources by default.
Testing and quality guidelines
- Must pass
charm test
. - Results must not result in errors or warnings. These are shown as an E: or W: in
charm test
's output. - Must include tests. Testing is defined as unit tests, functional tests, or integration tests. The tests must exercise:
- Relations
- Validate all relations that the charm provides and requires
- Configuration
- As a minimum, test setting and resetting parameters (
config
andconfig --reset
- Deployment testing
- Scale test: Production deployment test with multiple units and recommended config.
- Smoke test: Bare minimum to have the application working
- Must not use anything infrastructure-provider specific (i.e. querying EC2 metadata service) or symlinks. Must be self contained within a charm unless the charm is a proxy for an existing cloud service, eg.
ec2-elb
charm. - Bundles must only use charms which are already in the store, they cannot reference charms in personal namespaces.
- Must call Juju API tools (
relation-*
,unit-*
,config-*
, etc) without a hard coded path.
- Should include
tests.yaml
for all integration tests
Metadata guidelines
- Must include a full description of what the software does in the metadata.
- Must have a maintainer email address in metadata.yaml attached to a team or individual who are responsive to contact.
- Must include a license. Call the file ‘copyright’ and make sure all files’ licenses are specified clearly.
- Must be under a Free license.
- Must have a well documented and valid
README.md
. - Fill out the relevant sections as provided by
charm add readme
. - Must describe the application.
- Must describe how it interacts with other applications, if applicable.
- Must document the interfaces.
- Must show how to deploy the charm.
- Must define external dependencies, if applicable.
- Should link to a recommend production usage bundle and recommended configuration if this differs from the default.
- Should reference and link to upstream documentation and best practices.
Security guidelines
- Must not run any network applications using default passwords.
- Must verify and validate any external payload
- Known and understood packaging systems that verify packages like apt, pip, and yum are ok.
wget | sh
style is not ok.
- Should make use of whatever Mandatory Access Control system is provided by the distribution:
- AppArmor for Ubuntu.
- SELinux for CentOS systems.
- Should avoid running applications as root.
Other
The charm store referred to in this document is the collection of Juju charms and bundles hosted at https://launchpad.net/charms.
If a charm is no longer being properly maintained and is failing to adhere to policy the charm will undergo the unmaintained charm process. This process confirms the charm is no longer being maintained, fails to adhere to Charm Store policy, and thus is removed from the recommended status in the Juju Charm Store.
Charm metadata
metadata.yaml
This file is an important component of a charm.
Check out the [MySQL metadata.yaml] (~charmers/charms/precise/mysql/trunk : contents of metadata.yaml at revision 129) as an example.
config.yaml
Any de-facto config options must be kept at least until the next major charm series release. Removed config options should be deprecated first by noting that they are deprecated, and why, in their description. Instructions for converting values must be added to README as well.
Each configuration option must have type
, description
, and default
fields that give users more information about the option and how it can be used.
README.md
Charms that want to display instructions to users can do so in plain text by including a file called README. If the author would like to use Markdown, the file should be called README.md, and if the author would like to use restructured text, the file should be called README.rst. Only one of these files can be included in the charm. We recommend Markdown due to its popularity and tooling.
Remember that the README is used by the GUI and website as the default “front page” of the charm: it is user facing and should include easy to read instructions for deployment.
A bundle’s README is used by the GUI and the website as the default “front page” of the bundle, so it should not only include information on how to use the bundle, but also mention which charms the bundle contains and how the bundle is meant to be used.
Interfaces
Charms should only implement a new interface when existing interfaces are insufficient to achieve the goal of the charm. Interfaces that have an official requires/provides in the charm store cannot be changed by adding required fields or removing existing fields. New optional fields can be added at any time.
The charm store series denotes the OS release that the charms which are contained within it are intended to run on.
State
Each series can be in one of these states:
- Experimental - Charms can be added, but are in a state of flux.
- Active - The Charm store is actively accepting new charms and changes.
- Frozen - Only critical fixes are accepted.
- EOL - The OS version is not supported by the vendor, and thus, neither are the charms.
Experimental
Experimental series charms should adhere to the charm policy except that interfaces are never made ‘de-facto’ in an experimental series.
- Active - When a series is active, all changes are subject to the de-facto rules above.
- Frozen - The charmers team on launchpad has discretion when a series is frozen as to whether or not a change should be accepted.
- EOL - No changes will be accepted except those which help users who need to migrate to a supported series.
- Process - Charm store releases will be moved from Active to Frozen periodically to allow de-facto changes to settle and allow testing of infrastructure. New releases of target OS’s will be reflected in the Charm Store as an experimental series. There can be multiple Active series at one time. Maintainers can choose whether or not to support their charm in all of the Active series, as long as the charm is maintained in at least one Active series.
