The information in this doc is based on Juju version 3.5.3, and may not accurately reflect other versions of Juju.
See also: machines, show-model, show-status-log, storage
Report the status of the model, its machines, applications and units.
Usage
juju status [options] [<selector> [...]]
Options
Flag | Default | Usage |
-B , --no-browser-login |
--color |
false | Use ANSI color codes in tabular output |
--format |
tabular | Specify output format (json|line|oneline|short|summary|tabular|yaml) |
--integrations |
false | Show ‘integrations’ section in tabular output |
-m , --model |
--no-color |
false | Disable ANSI color codes in tabular output |
-o , --output |
Specify an output file | |
--relations |
false | The same as ‘–integrations’ |
--retry-count |
3 | Number of times to retry API failures |
--retry-delay |
100ms | Time to wait between retry attempts |
--storage |
false | Show ‘storage’ section in tabular output |
--utc |
false | Display timestamps in the UTC timezone |
--watch |
0s | Watch the status every period of time |
Examples
Report the status of units hosted on machine 0:
juju status 0
Report the status of the the mysql application:
juju status mysql
Report the status for applications that start with nova-:
juju status nova-*
Include information about storage and integrations in output:
juju status --storage --integrations
Provide output as valid JSON:
juju status --format=json
Watch the status every five seconds:
juju status --watch 5s
Show only applications/units in active status:
juju status active
Show only applications/units in error status:
juju status error
Details
Report the model’s status, optionally filtered by names of applications or units. When selectors are present, filter the report to exclude entities that do not match.
juju status [<selector> [...]]
<selector> selects machines, units or applications from the model to display. Wildcard characters (*) enable multiple entities to be matched at the same time.
(<machine>|<unit>|<application>)[*]
When an entity that matches <selector> is integrated with other applications, the status of those applications will also be presented. By default (without a <selector>) the status of all applications and their units will be displayed.
Altering the output format
The ‘–format’ option allows you to specify how the status report is formatted.
–format=tabular (default) Display information about all aspects of the model in a human-centric manner. Omits some information by default. Use the ‘–integrations’ and ‘–storage’ options to include all available information.
–format=line –format=short –format=oneline Reports information from units. Includes their IP address, open ports and the status of the workload and agent.
–format=summary Reports aggregated information about the model. Includes a description of subnets and ports that are in use, the counts of applications, units, and machines by status code.
–format=json –format=yaml Provide information in a JSON or YAML formats for programmatic use.
