The information in this doc is based on Juju version 3.5.4, and may not accurately reflect other versions of Juju.
See also: login, controllers, status
Migrate a workload model to another controller.
Usage
juju migrate [options] <model-name> <target-controller-name>
Options
Flag | Default | Usage |
-B , --no-browser-login |
Details
The ‘migrate’ command begins the migration of a workload model from its current controller to a new controller. This is useful for load balancing when a controller is too busy, or as a way to upgrade a model’s controller to a newer Juju version.
In order to start a migration, the target controller must be in the juju client’s local configuration cache. See the ‘login’ command for details of how to do this.
The ‘migrate’ command only starts a model migration - it does not wait for its completion. The progress of a migration can be tracked using the ‘status’ command and by consulting the logs.
Once the migration is complete, the model’s machine and unit agents will be connected to the new controller. The model will no longer be available at the source controller.
If the migration fails for some reason, the model is returned to its original state where it is managed by the original controller.
