Command 'juju run'
The information in this doc is based on Juju version 3.5.5, and may not accurately reflect other versions of Juju.
See also: operations, show-operation, show-task
Run an action on a specified unit.
Usage
juju run [options] <unit> [<unit> ...] <action-name> [<key>=<value> [<key>[.<key> ...]=<value>]]
Options
Flag Default Usage
-B, --no-browser-login false Do not use web browser for authentication
--background false Run the task in the background
--color false Use ANSI color codes in output
--format plain Specify output format (json|plain|yaml)
-m, --model Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
--no-color false Disable ANSI color codes in output
-o, --output Specify an output file
--params Path to yaml-formatted params file
--string-args false Use raw string values of CLI args
--utc false Show times in UTC
--wait 0s Maximum wait time for a task to complete
Examples
juju run mysql/3 backup --background
juju run mysql/3 backup --wait=2m
juju run mysql/3 backup --format yaml
juju run mysql/3 backup --utc
juju run mysql/leader backup
juju show-operation <ID>
juju run mysql/3 backup --params parameters.yml
juju run mysql/3 backup out=out.tar.bz2 file.kind=xz file.quality=high
juju run mysql/3 backup --params p.yml file.kind=xz file.quality=high
juju run sleeper/0 pause time=1000
juju run sleeper/0 pause --string-args time=1000
Details
Run a charm action for execution on the given unit(s), with a given set of params. An ID is returned for use with ‘juju show-operation <ID>’.
A action executed on a given unit becomes a task with an ID that can be used with ‘juju show-task <ID>’.
Running an action returns the overall operation ID as well as the individual task ID(s) for each unit.
To queue a action to be run in the background without waiting for it to finish, use the --background option.
To set the maximum time to wait for a action to complete, use the --wait option.
By default, a single action will output its failure message if the action fails, followed by any results set by the action. For multiple actions, each action’s results will be printed with the action id and action status. To see more detailed information about run timings etc, use --format yaml.
Valid unit identifiers are: a standard unit ID, such as mysql/0 or; leader syntax of the form <application>/leader, such as mysql/leader.
If the leader syntax is used, the leader unit for the application will be resolved before the action is enqueued.
Params are validated according to the charm for the unit’s application. The valid params can be seen using “juju actions <application> --schema”. Params may be in a yaml file which is passed with the --params option, or they may be specified by a key.key.key…=value format (see examples below.)
Params given in the CLI invocation will be parsed as YAML unless the –string-args option is set. This can be helpful for values such as ‘y’, which is a boolean true in YAML.
If --params is passed, along with key.key…=value explicit arguments, the explicit arguments will override the parameter file.
