Command 'juju actions'
The information in this doc is based on Juju version 3.5.4, and may not accurately reflect other versions of Juju.
See also: run, show-action
List actions defined for an application.
Usage
juju actions [options] <application>
Options
Flag Default Usage
-B, --no-browser-login false Do not use web browser for authentication
--format default Specify output format (default|json|tabular|yaml)
-m, --model Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
-o, --output Specify an output file
--schema false Display the full action schema
Examples
juju actions postgresql
juju actions postgresql --format yaml
juju actions postgresql --schema
Details
List the actions available to run on the target application, with a short description. To show the full schema for the actions, use --schema.
