Command 'juju enable-command'
The information in this doc is based on Juju version 3.5.6, and may not accurately reflect other versions of Juju.
See also: disable-command, disabled-commands
Enable commands that had been previously disabled.
Usage
juju enable-command [options] <command set>
Options
Flag Default Usage
-B, --no-browser-login false Do not use web browser for authentication
-m, --model Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
Examples
To allow the model to be destroyed:
juju enable-command destroy-model
To allow the machines, applications, units and relations to be removed:
juju enable-command remove-object
To allow changes to the model:
juju enable-command all
Details
Juju allows to safeguard deployed models from unintentional damage by preventing execution of operations that could alter model.
This is done by disabling certain sets of commands from successful execution. Disabled commands must be manually enabled to proceed.
Some commands offer a --force option that can be used to bypass a block.
Commands that can be disabled are grouped based on logical operations as follows:
“destroy-model” prevents: destroy-controller destroy-model
“remove-object” prevents: destroy-controller destroy-model detach-storage remove-application remove-machine remove-relation remove-saas remove-storage remove-unit
“all” prevents: add-machine integrate add-unit add-ssh-key add-user attach-resource attach-storage change-user-password config consume deploy destroy-controller destroy-model disable-user enable-ha enable-user expose import-filesystem import-ssh-key model-defaults model-config reload-spaces remove-application remove-machine remove-relation remove-ssh-key remove-unit remove-user resolved retry-provisioning run scale-application set-application-base
set-credential set-constraints sync-agents unexpose refresh upgrade-model
