Command 'juju list-disabled-commands'
The information in this doc is based on Juju version 3.5.5, and may not accurately reflect other versions of Juju.
See also: disable-command, enable-command Alias: disabled-commands
List disabled commands.
Options
Flag Default Usage
-B, --no-browser-login false Do not use web browser for authentication
--all false Lists for all models (administrative users only)
--format tabular Specify output format (json|tabular|yaml)
-m, --model Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
-o, --output Specify an output file
Details
List disabled commands for the model.
Commands that can be disabled are grouped based on logical operations as follows:
“destroy-model” prevents: destroy-controller destroy-model
“remove-object” prevents: destroy-controller destroy-model detach-storage remove-application remove-machine remove-relation remove-saas remove-storage remove-unit
“all” prevents: add-machine integrate add-unit add-ssh-key add-user attach-resource attach-storage change-user-password config consume deploy destroy-controller destroy-model disable-user enable-ha enable-user expose import-filesystem import-ssh-key model-defaults model-config reload-spaces remove-application remove-machine remove-relation remove-ssh-key remove-unit remove-user resolved retry-provisioning run scale-application set-application-base
set-credential set-constraints sync-agents unexpose refresh upgrade-model
