See also: disabled-commands, enable-command
Disable commands for the model.
Usage
juju disable-command [options] <command set> [message...]
Options
| Flag | Default | Usage |
--B, --no-browser-login |
--m, --model |
Model to operate in. Accepts [<controller name>:]<model name>|<model UUID> |
Examples
To prevent the model from being destroyed:
juju disable-command destroy-model "Check with SA before destruction."
To prevent the machines, applications, units and relations from being removed:
juju disable-command remove-object
To prevent changes to the model:
juju disable-command all "Model locked down"
Details
Juju allows to safeguard deployed models from unintentional damage by preventing execution of operations that could alter model.
This is done by disabling certain sets of commands from successful execution. Disabled commands must be manually enabled to proceed.
Some commands offer a --force option that can be used to bypass the disabling.
Commands that can be disabled are grouped based on logical operations as follows:
“destroy-model” prevents: destroy-controller destroy-model
“remove-object” prevents: destroy-controller destroy-model detach-storage remove-application remove-machine remove-relation remove-saas remove-storage remove-unit
“all” prevents:
add-machine
integrate
add-unit
add-ssh-key
add-user
attach-resource
attach-storage
change-user-password
config
consume
deploy
destroy-controller
destroy-model
disable-user
enable-ha
enable-user
expose
import-filesystem
import-ssh-key
model-defaults
model-config
reload-spaces
remove-application
remove-machine
remove-relation
remove-ssh-key
remove-unit
remove-user
resolved
retry-provisioning
run
scale-application
set-application-base
set-credential
set-constraints
sync-agents
unexpose
refresh
upgrade-model
