See also: disable-command, enable-command Alias: disabled-commands
List disabled commands.
Options
| Flag | Default | Usage |
--B, --no-browser-login |
--all |
false | Lists for all models (administrative users only) |
--format |
tabular | Specify output format (json|tabular|yaml) |
--m, --model |
--o, --output |
Specify an output file |
Details
List disabled commands for the model.
Commands that can be disabled are grouped based on logical operations as follows:
“destroy-model” prevents: destroy-controller destroy-model
“remove-object” prevents: destroy-controller destroy-model detach-storage remove-application remove-machine remove-relation remove-saas remove-storage remove-unit
“all” prevents:
add-machine
integrate
add-unit
add-ssh-key
add-user
attach-resource
attach-storage
change-user-password
config
consume
deploy
destroy-controller
destroy-model
disable-user
enable-ha
enable-user
expose
import-filesystem
import-ssh-key
model-defaults
model-config
reload-spaces
remove-application
remove-machine
remove-relation
remove-ssh-key
remove-unit
remove-user
resolved
retry-provisioning
run
scale-application
set-application-base
set-credential
set-constraints
sync-agents
unexpose
refresh
upgrade-model
