Command 'charmcraft analyse'
Usage:
charmcraft analyse [options] <filepath>
Summary:
Analyze a charm.
Report the attributes and lint results directly in the terminal. Use --force to run even those configured to be ignored.
Options:
-h, --help Show this help message and exit
-v, --verbose Show debug information and be more verbose
-q, --quiet Only show warnings and errors, not progress
--verbosity Set the verbosity level to ‘quiet’, ‘brief’, ‘verbose’, ‘debug’ or ‘trace’
-V, --version Show the application version and exit
-p, --project-dir Specify the project’s directory (defaults to current)
--format Produce the result in the specified format (currently only ‘json’)
--ignore Linters to ignore (comma separated)
See also:
  • analyze
  • version
