Update a resource for an application.
Usage
juju attach-resource [options] application name=file|OCI image
Options
Flag | Default | Usage |
--B , --no-browser-login
--m , --model
Model to operate in. Accepts [<controller name>:]<model name>|<model UUID> |
Details
This command updates a resource for an application.
For file resources, it uploads a file from your local disk to the juju controller to be streamed to the charm when “resource-get” is called by a hook.
For OCI image resources used by k8s applications, an OCI image or file path is specified. A file is specified when a private OCI image is needed and the username/password used to access the image is needed along with the image path.
