Command 'juju list-charm-resources'
The information in this doc is based on Juju version 3.5.3, and may not accurately reflect other versions of Juju.
See also: resources, attach-resource Alias: charm-resources
Display the resources for a charm in a repository.
Usage
juju list-charm-resources [options] <charm>
Options
Flag Default Usage
-B, --no-browser-login false Do not use web browser for authentication
--channel stable the channel of the charm
--format tabular Specify output format (json|tabular|yaml)
-m, --model Model to operate in. Accepts [<controller name>:]<model name>|<model UUID>
-o, --output Specify an output file
Examples
Display charm resources for the postgresql charm:
juju charm-resources postgresql
Display charm resources for mycharm in the 2.0/edge channel:
juju charm-resources mycharm --channel 2.0/edge
Details
This command will report the resources and the current revision of each resource for a charm in a repository.
Channel can be specified with --channel. If not provided, stable is used.
Where a channel is not supplied, stable is used.
