Authorization
Enabling authorization requires that you have an active Charmed Temporal K8s Operator deployed as described in the tutorial. It is recommended that you first go through the steps of enabling authentication as outlined here.
By default the Temporal Server doesn’t offer any authorization, but it offers the plugin mechanism to add a custom one. We have added an OAuth-based authentication using Google Cloud and an authorization mechanism that leverages Google Cloud and OpenFGA. This custom build of the Temporal Server can be found here.
Deploy OpenFGA
To deploy Charmed OpenFGA K8s, you need to run the following command, which will fetch the charm from Charmhub and deploy it to your model:
juju deploy openfga-k8s --channel edge
Wait until the application is ready - when it is ready, juju status will show:
temporal-model temporal-controller microk8s/localhost 3.1.5 unsupported 12:35:24+03:00
openfga-k8s blocked 1 openfga-k8s edge 9 10.152.183.144 no installing agent
postgresql-k8s 14.7 active 1 postgresql-k8s 14/stable 73 10.152.183.250 no Primary
temporal-admin-k8s active 1 temporal-admin-k8s stable 4 10.152.183.21 no
temporal-k8s active 1 temporal-k8s stable 9 10.152.183.191 no
openfga-k8s/0* blocked idle 10.1.232.7 Waiting for postgresql relation
postgresql-k8s/0* active idle 10.1.232.66 Primary
temporal-admin-k8s/0* active idle 10.1.232.71
temporal-k8s/0* active idle 10.1.232.64
Relate OpenFGA K8s to PostgreSQL K8s
To relate the two charms together, run the following command:
juju relate openfga-k8s postgresql-k8s
Wait until the charm has settled - when ready, juju status --relations will
show:
openfga-k8s active 1 openfga-k8s edge 9 10.152.183.144 no
openfga-k8s/0* active idle 10.1.232.7
openfga-k8s:peer openfga-k8s:peer openfga-peer peer
postgresql-k8s:database openfga-k8s:database postgresql_client regular
postgresql-k8s:database temporal-k8s:db postgresql_client regular
postgresql-k8s:database temporal-k8s:visibility postgresql_client regular
postgresql-k8s:database-peers postgresql-k8s:database-peers postgresql_peers peer
postgresql-k8s:restart postgresql-k8s:restart rolling_op peer
temporal-admin-k8s:admin temporal-k8s:admin temporal regular
temporal-k8s:peer temporal-k8s:peer temporal peer
At this point, we have a functioning OpenFGA store which we can now use to store namespace access rules.
Relate Temporal K8s to OpenFGA K8s
To enable authorization, we must first configure the Temporal Server as follows:
juju config temporal-k8s auth-enabled=true
At this point, the temporal-k8s application should be in a blocked state
with a message openfga:temporal relation not ready. We can now relate the two
charms together by running the following command:
juju relate temporal-k8s openfga-k8s
Once the units settle, the temporal-k8s application should still be in a
blocked state, but with an updated message
missing openfga authorization model. We can now create an
authorization model in the OpenFGA store by
juju run temporal-k8s/0 create-authorization-model model="$(<temporal_auth_model.json)" --string-args=true
show:
temporal-k8s/0* active idle 10.1.232.64 auth enabled
openfga-k8s:openfga temporal-k8s:openfga openfga regular
At this point, our Temporal Server is active again with authorization enabled. This means that any request made to the Temporal Server will need to be authenticated using Google OAuth.
Create OpenFGA Authorization Rules
Once authorization is enabled, you will not be able to access any namespace in Temporal. You must now create the necessary tuples in the OpenFGA store to enable users read/write access to different namespaces.
The authorization model used is as follows:
model
schema 1.1
type user
type group
relations
define member: [user]
type namespace
relations
define admin: [group#member]
define reader: [group#member] or writer
define writer: [group#member] or admin
The above model is a simple way of relating users to groups to namespaces. A
user can be related to a group as a member, and a group can be related
to a namespace as either a reader, writer or admin. For example, if user
john is a member of group abc, and group abc is related to namespace
example as a writer, then user john will be assigned write access on
namespace example.
To add authorization rules to our OpenFGA store, we can use the available actions as follows:
# Add user to group:
juju run temporal-k8s/0 add-auth-rule user="<your_email>" group="test_group"
# Output:
Running operation 19 with 1 task
- task 20 on unit-temporal-k8s-0
Waiting for task 20...
output: 'operation type "create" for user "<your_email>" on group "test_group" successful'
result: command succeeded
# Assign group 'writer' role to namespace:
juju run temporal-k8s/0 add-auth-rule group="test_group" namespace="default" role="writer"
# Output:
output: 'operation type "create" for group "test_group" and role "writer" on namespace "default" successful'
And you’re done! If the above actions ran successfully, you should be able to
access the default namespace in Temporal with the authenticated user
identified by <your_email>, whether through web UI login or the use of a
Google Cloud service account.
The following actions may also be used for removing auth rules, checking access rules and for auditing purposes:
# 1. Check auth rule
juju run temporal-k8s/0 check-auth-rule user="<your_email>" namespace="default" role="writer"
# Output:
output: "True"
# 2. List auth rules
juju run temporal-k8s/0 list-auth-rule user="<your_email>"
# Output:
output: |
admin: '[]'
member: '[''group:test_group'']'
reader: '[''namespace:default'']'
writer: '[''namespace:default'']'
# 3. Remove auth rule
juju run temporal-k8s/0 remove-auth-rule user="<your_email>" group="test_group"
# Output:
output: 'operation type "delete" for user "<your_email>" on group "test_group" successful'
Temporal System Admins
A Temporal System Admin refers to anyone who has access to all namespaces, as well as the ability to administer namespace creation and removal. This can be enabled as follows:
# Configure admin group (can be multiple comma-separated groups) and add system admin
juju config temporal-k8s auth-admin-groups="admins"
juju run temporal-k8s/0 add-auth-rule user="<your_email>" group="admins"
# List system admins
juju run temporal-k8s/0 list-system-admins
# Output:
output:
admins: '[''<your_email>'']'
Once configured, the user with <your_email> will be able to see all namespaces
through the Web UI as well as create new namespaces using
the CLI.
