CLI helpers
This page describes some useful low-level tools shipped withing Charmed PostgreSQL for advanced troubleshooting.
These tools can be dangerous in a production environment if they are not used correctly.
When in doubt, contact us.
Patroni
Troubleshooting tools include:
- The command-line tool
patronictl - The Patroni REST API
- The Raft library
Learn more about Patroni in the Architecture page.
patronictl
The main Patroni tool is patronictl.
It should only be used under the snap context, via the user snap_daemon.
Cluster status
patronictl checks the low-level Patroni status of the cluster.
Example: cluster status
> juju deploy postgresql -n 3 # and wait for deployment
> juju ssh postgresql/2
ubuntu@juju-b87344-2:~$ sudo -u snap_daemon patronictl -c /var/snap/charmed-postgresql/current/etc/patroni/patroni.yaml topology
+ Cluster: postgresql (7496847632512033809) ------+-----------+----+-----------+
| Member | Host | Role | State | TL | Lag in MB |
| postgresql-1 | 10.189.210.201 | Leader | running | 1 | |
| + postgresql-2 | 10.189.210.55 | Sync Standby | streaming | 1 | 0 |
| + postgresql-3 | 10.189.210.26 | Sync Standby | streaming | 1 | 0 |
Useful Patroni actions
Use --help to find all the available Patroni actions.
Example: Patroni actions
> sudo -u snap_daemon patronictl -c /var/snap/charmed-postgresql/current/etc/patroni/patroni.yaml --help
failover Failover to a replica
history Show the history of failovers/switchovers
list List the Patroni members for a given Patroni
pause Disable auto failover
query Query a Patroni PostgreSQL member
reinit Reinitialize cluster member
reload Reload cluster member configuration
remove Remove cluster from DCS
restart Restart cluster member
resume Resume auto failover
switchover Switchover to a replica
topology Prints ASCII topology for given cluster
Switchover/failover
Patroni can perform a low-level switchover/failover inside one cluster.
Example: switchover (healthy cluster only)
ubuntu@juju-b87344-2:~$ sudo -u snap_daemon patronictl -c /var/snap/charmed-postgresql/current/etc/patroni/patroni.yaml switchover postgresql --candidate postgresql-2 --force
Current cluster topology
+ Cluster: postgresql (7496847632512033809) ----+-----------+----+-----------+
| postgresql-1 | 10.189.210.201 | Sync Standby | streaming | 2 | 0 |
| postgresql-2 | 10.189.210.55 | Sync Standby | streaming | 2 | 0 |
| postgresql-3 | 10.189.210.26 | Leader | running | 2 | |
2025-04-25 04:59:10.87214 Successfully switched over to "postgresql-2"
+ Cluster: postgresql (7496847632512033809) -----------+----+-----------+
| postgresql-1 | 10.189.210.201 | Replica | running | 2 | 0 |
| postgresql-2 | 10.189.210.55 | Leader | running | 2 | |
| postgresql-3 | 10.189.210.26 | Replica | stopped | | unknown |
ubuntu@juju-b87344-2:~$ sudo -u snap_daemon patronictl -c /var/snap/charmed-postgresql/current/etc/patroni/patroni.yaml list
| postgresql-1 | 10.189.210.201 | Sync Standby | streaming | 3 | 0 |
| postgresql-2 | 10.189.210.55 | Leader | running | 3 | |
| postgresql-3 | 10.189.210.26 | Sync Standby | streaming | 3 | 0 |
Example: failover
ubuntu@juju-b87344-2:~$ sudo -u snap_daemon patronictl -c /var/snap/charmed-postgresql/current/etc/patroni/patroni.yaml failover postgresql --candidate postgresql-3
Current cluster list
Are you sure you want to failover cluster postgresql, demoting current leader postgresql-1? [y/N]: y
2025-04-25 04:44:53.69748 Successfully failed over to "postgresql-3"
+ Cluster: postgresql (7496847632512033809) ---------+----+-----------+
| postgresql-1 | 10.189.210.201 | Replica | stopped | | unknown |
| postgresql-2 | 10.189.210.55 | Replica | running | 1 | 0 |
| postgresql-3 | 10.189.210.26 | Leader | running | 1 | |
ubuntu@juju-b87344-2:~$ sudo -u snap_daemon patronictl -c /var/snap/charmed-postgresql/current/etc/patroni/patroni.yaml history
| TL | LSN | Reason | Timestamp | New Leader |
| 1 | 335544480 | no recovery target specified | 2025-04-25T04:44:53.137152+00:00 | postgresql-3 |
Re-initialisation
Sometimes the cluster member might stuck in the middle of nowhere, the easiest way to try is reinit the Patroni cluster member.
Example: cluster member re-initialization
ubuntu@juju-b87344-2:~$ sudo -u snap_daemon patronictl -c /var/snap/charmed-postgresql/current/etc/patroni/patroni.yaml reinit postgresql postgresql-1
Are you sure you want to reinitialize members postgresql-1? [y/N]: y
Success: reinitialize for member postgresql-1
Patroni REST API
Patroni provides most patronictl actions as a REST API. Use port 8008 to access Patroni REST API on any member/unit of Charmed PostgreSQL.
Example: read-only access via Patroni REST API
ubuntu@juju360:~$ curl 10.189.210.55:8008/cluster | jq # where 10.189.210.55 is IP of Charmed PostgreSQL Juju unit
"members": [
"name": "postgresql-1",
"role": "sync_standby",
"state": "streaming",
"api_url": "http://10.189.210.201:8008/patroni",
"host": "10.189.210.201",
"port": 5432,
"timeline": 3,
"lag": 0
"name": "postgresql-2",
"role": "leader",
"state": "running",
"api_url": "http://10.189.210.55:8008/patroni",
"host": "10.189.210.55",
"port": 5432,
"timeline": 3
"name": "postgresql-3",
"api_url": "http://10.189.210.26:8008/patroni",
"host": "10.189.210.26",
"port": 5432,
"timeline": 3,
"lag": 0
"scope": "postgresql"
Note: Patroni REST API can be accessed anonymously in read-only mode only. The Juju secret
patroni-passwordis mandatory to apply any chances via Patroni REST API. Example of authenticated changes via Patroni REST API:
Example: write access via Patroni REST API
> juju secrets | grep postgresql # find ID with 'patroni-password'
> juju show-secret --reveal ccccaaabbbbbbcgoi12345 | grep patroni-password # reveal password to access Patroni REST API
patroni-password: patr0n1sup3rs3cretpassw0rd
> curl -k -u patroni:patr0n1sup3rs3cretpassw0rd -X POST https://10.151.27.242:8008/switchover -d '{"leader": "postgresql-0", "candidate": "postgresql-1"}'
Successfully switched over to "postgresql-1"
Hint: use dedicated promote-to-primary action to switchover Primary.
Pay attention to TLS relation with PostgreSQL and access Patroni REST API accordingly:
Example: access Patroni REST API with(out) TLS
> curl http://x.x.x.x:8008/cluster # to access without TLS
> curl https://x.x.x.x:8008/cluster # to access with trusted certificate
> curl -k https://x.x.x.x:8008/cluster # to access with self-signed certificate
Raft library
Patroni relies on the Raft library for the consensus handling and Primary election. It is implemented using pySyncObj and available as a CLI tool.
While you should not interact with Raft library manually, you can check its internal status:
Example: check Raft status
> juju secrets | grep postgresql # find ID with 'raft-password'
> juju show-secret --reveal cvia1ibjihbbbcgoi12300 | grep raft-password # reveal password to access Raft
raft-password: r@ftsup3rs3cretp@ssw0rd
ubuntu@juju-b87344-2:~$ charmed-postgresql.syncobj-admin -status -conn 10.151.27.242:2222 -pass r@ftsup3rs3cretp@ssw0rd # where IP is a PostgreSQL Juju unit IP
commit_idx: 1396297
enabled_code_version: 0
has_quorum: True <<<<<<<<<<<< Important Raft cluster health!
last_applied: 1396297
leader: 10.151.27.205:2222 <<<<<<<<<<<< Shows you the Raft leader
leader_commit_idx: 1396297
log_len: 69
match_idx_count: 2
match_idx_server_10.151.27.103:2222: 1310986
match_idx_server_10.151.27.205:2222: 1310986
next_node_idx_count: 2
next_node_idx_server_10.151.27.103:2222: 1310987
next_node_idx_server_10.151.27.205:2222: 1310987
partner_node_status_server_10.151.27.103:2222: 2
partner_node_status_server_10.151.27.205:2222: 2
partner_nodes_count: 2
raft_term: 92
readonly_nodes_count: 0 <<<<<<<<<<<< Raft members health
revision: deprecated
self: 10.151.27.242:2222
self_code_version: 0
state: 0 <<<<<<<<<<<< Self health
uptime: 2482881
version: 0.3.12
Note: password is mandatory to access Raft.
Note: pay attention to the CLI syntax (simple
-used, avoid misstype with common--prefix for parametes)
PostgreSQL tools
The Charmed PostgreSQL ships long list of standard pg_* tools, including pg_dump, pg_dumpall (and more). Due to the SNAP naming requirements they are available as pg-dump and pg-dumpall accordingly.
The entire list can bu found on systems with snap charmed-postgresql installed, e.g.:
Example: list of pg_* tools shipped by snap
> snap list charmed-postgresql
Name Version Rev Tracking Publisher Notes
charmed-postgresql 14.15 143 latest/stable canonical✓ held
> charmed-postgresql.pg<TAB><TAB>
charmed-postgresql.pg-archivecleanup charmed-postgresql.pg-conftool charmed-postgresql.pg-dump charmed-postgresql.pg-recvlogical charmed-postgresql.pg-upgradecluster charmed-postgresql.pgbouncer-server
charmed-postgresql.pg-backupcluster charmed-postgresql.pg-createcluster charmed-postgresql.pg-dumpall charmed-postgresql.pg-renamecluster charmed-postgresql.pg-virtualenv
charmed-postgresql.pg-basebackup charmed-postgresql.pg-ctl charmed-postgresql.pg-isready charmed-postgresql.pg-restore charmed-postgresql.pgbackrest
charmed-postgresql.pg-buildext charmed-postgresql.pg-ctlcluster charmed-postgresql.pg-lsclusters charmed-postgresql.pg-restorecluster charmed-postgresql.pgbench
charmed-postgresql.pg-config charmed-postgresql.pg-dropcluster charmed-postgresql.pg-receivewal charmed-postgresql.pg-updatedicts charmed-postgresql.pgbouncer
pg_dump / pg_dumpall
Those tools are designed to dump the PostgreSQL content. Due to the strictly confined SNAP, the context is limited to SNAP itself (and not the POSIX user triggered the tool). Also, due to security reasons the default postgres user cannot access DB, use user operator (you can find it’s credential in Juju Secrets).
Example: pg-dump/pg-dumpall usage
charmed-postgresql.pg-dump -c -C -U operator -W -h /tmp -d mydb | tee mydb.sql >/dev/null
Also you can pass password using env variable PGPASSWORD, however it is NOT recommended for productions as DB password will be stored in shell history:
PGPASSWORD=my$ecretp@ss charmed-postgresql.pg-dumpall -c -U operator -h /tmp | tee all_DBs.txt >/dev/null
Note, the local SNAP /tmp could be used as well:
PGPASSWORD=my$ecretp@ss charmed-postgresql.pg-dumpall -c -U operator -h /tmp -f /tmp/test.sql
> sudo ls -la /tmp/snap-private-tmp/snap.charmed-postgresql/tmp/test.sql
-rw-rw-r-- 1 ubuntu ubuntu 19416 Jun 4 08:24 /tmp/snap-private-tmp/snap.charmed-postgresql/tmp/test.sql
