Reference
Technical specifications, APIs, release notes, and other reference material for fast lookup.
- Releases - Overview of major revisions of this charm
- System requirements
- Software testing
- Performance and resources
- Troubleshooting
- CLI helpers - Patroni CLI tools for troubleshooting
- Plugins/extensions
- Alert rules - Pre-configured Prometheus alert rules
- Statuses - Juju application statuses
- Contacts
In the tabs at the top of this charm’s Charmhub page, you can find the following automatically generated API references:
| Page | Description |
| Integrations | Integration/relation interfaces supported by this charm |
| Libraries | VM charm library is empty as charm uses K8s library (more info here) |
| Configuration | Application configuration parameters |
| Actions | Juju actions supported by this charm |
