Charmed PostgreSQL K8s Tutorial > 5. Integrate applications
Integrations, known as “relations” in Juju 2.9, are the easiest way to create a user for PostgreSQL in Charmed PostgreSQL K8s.
Integrations automatically create a username, password, and database for the desired user/application. As mentioned earlier in 3. Deploy PostgreSQL > Access PostgreSQL, it is a better practice to connect to PostgreSQL via a specific user rather than the admin user.
In this section, you will integrate your Charmed PostgreSQL to another charmed application.
juju run
injuju v.2.9
juju integrate
replacesjuju relate
andjuju add-relation
injuju v.2.9
Data Integrator Charm
Before relating to a charmed application, we must first deploy our charmed application. In this tutorial, we will relate to the Data Integrator Charm. This is a bare-bones charm that allows for central management of database users, providing support for different kinds of data platforms (e.g. PostgreSQL, MySQL, MongoDB, Kafka, etc) with a consistent, opinionated and robust user experience.
In order to deploy the Data Integrator Charm, we can use the command juju deploy
we have learned above:
juju deploy data-integrator --channel edge --config database-name=test-database
The expected output:
Located charm "data-integrator" in charm-hub, revision 6
Deploying "data-integrator" from charm-hub charm "data-integrator", revision 6 in channel edge on jammy
Checking the deployment progress using juju status
will show a blocked
state for the newly deployed charm:
tutorial charm-dev microk8s/localhost 2.9.42 unsupported 12:11:53+01:00
data-integrator waiting 1 data-integrator edge 6 10.152.183.66 no installing agent
postgresql-k8s active 2 postgresql-k8s 14/stable 56 10.152.183.167 no
data-integrator/0* blocked idle 10.1.188.211 Please relate the data-integrator with the desired product
postgresql-k8s/0* active idle 10.1.188.206
postgresql-k8s/1 active idle 10.1.188.209
The blocked
state is expected due to not-yet established relation (integration) between applications.
Relate to PostgreSQL
Now that the Database Integrator Charm has been set up, we can relate it to PostgreSQL. This will automatically create a username, password, and database for the Database Integrator Charm.
Relate the two applications with:
juju integrate data-integrator postgresql-k8s
Wait for juju status --watch 1s
to show all applications/units as active
tutorial charm-dev microk8s/localhost 2.9.42 unsupported 12:12:12+01:00
data-integrator/0* active idle 10.1.188.211
To retrieve information such as the username, password, and database, run the command
This should output something like:
unit-data-integrator-0:
UnitId: data-integrator/0
results:
ok: "True"
postgresql:
database: test-database
endpoints: postgresql-k8s-primary.tutorial.svc.cluster.local:5432
password: WHnROd8wqzQKzd4F
read-only-endpoints: postgresql-k8s-replicas.tutorial.svc.cluster.local:5432
username: relation_id_3
version: "14.5"
status: completed
timing:
completed: 2023-03-20 11:12:26 +0000 UTC
enqueued: 2023-03-20 11:12:25 +0000 UTC
started: 2023-03-20 11:12:26 +0000 UTC
Note that your hostnames, usernames, and passwords will likely be different.
Access the related database
Use endpoints
, username
, password
from above to connect newly created database test-database
on the PostgreSQL server:
> psql --host=10.1.188.206 --username=relation_id_3 --password test-database
Password:
test-database=> \l
test-database | operator | UTF8 | en_US.UTF-8 | en_US.UTF-8 | =Tc/operator +
| | | | | operator=CTc/operator +
| | | | | relation_id_3=CTc/operator
The newly created database test-database
is also available on all other PostgreSQL cluster members:
> psql --host=10.89.49.209 --username=relation-3 --password --list
When you relate two applications, Charmed PostgreSQL K8s automatically sets up a new user and database for you.
Note the database name we specified when we first deployed the data-integrator
charm: --config database-name=test-database
Remove the user
Removing the integration automatically removes the user that was created when the integration was created. Enter the following to remove the integration:
juju remove-relation postgresql-k8s data-integrator
Now try again to connect to the same PostgreSQL you just used in Access the related database:
> psql --host=10.1.188.206 --username=relation_id_3 --password --list
This will output an error message like the one shown below:
psql: error: connection to server at "10.1.188.206", port 5432 failed: FATAL: password authentication failed for user "relation_id_3"
This is because the user no longer exists, as expected. Remember, juju remove-relation postgresql-k8s data-integrator
also removes the user.
Data remains on the server at this stage.
If you want to create a user again, integrate the applications again:
Re-integrating generates a new user and password:
You can then connect to the database with these new credentials. From here you will see all of your data is still present in the database.
