Charmed PostgreSQL K8s How to | Deploy on Canonical Kubernetes
How to deploy on Canonical Kubernetes
Canonical Kubernetes is a Kubernetes service built on Ubuntu and optimized for most major public clouds.
This guide shows you how to deploy Charmed PostgreSQL K8s to Canonical Kubernetes.
This guide assumes you have a spare hardware/VMs running Ubuntu 22.04 LTS (or newer).
Install Canonical Kubernetes
The following instructions are a complete but summarized version of the steps for installing Canonical K8s. For more thorough instructions and details, see the official Canonical Kubernetes documentation: Install Canonical Kubernetes from a snap.
Install, bootstrap, and check the status of Canonical K8s with the following commands:
sudo snap install k8s --edge --classic
sudo k8s bootstrap
sudo k8s status --wait-ready
Once Canonical K8s is up and running, enable local storage (or any another persistent volume provider, to be used by Juju Storage later):
sudo k8s enable local-storage
(Optional) Install kubectl tool and dump the K8s config:
sudo snap install kubectl --classic
mkdir ~/.kube
sudo k8s config > ~/.kube/config
kubectl get namespaces # to test the credentials
Install Juju
Install Juju and bootstrap the first Juju controller in K8s:
sudo snap install juju --channel 3.6/stable
juju add-k8s ck8s --client --context-name="k8s"
juju bootstrap ck8s
Deploy Charmed PostgreSQL K8s
juju add-model postgresql
juju deploy postgresql-k8s --trust
follow the deployment progress using:
juju status --watch 1s
Example output:
Model       Controller  Cloud/Region  Version  SLA          Timestamp
postgresql  ck8s        ck8s          3.6-rc1  unsupported  17:25:11+01:00
App             Version   Status  Scale  Charm           Channel     Rev  Address         Exposed  Message
postgresql-k8s  14.12     active      1  postgresql-k8s  14/stable   381  10.152.183.30   no
Unit               Workload  Agent  Address    Ports  Message
postgresql-k8s/0*  active    idle   10.1.0.16         Primary
Next steps: Learn how to scale your application, relate with other applications and more.
