Troubleshooting
Warning: At the moment, there is no ability to pause an operator.
Make sure your activity will not interfere with the operator itself!
juju runreplacesjuju run-action --waitinjuju v.2.9juju integratereplacesjuju relateandjuju add-relationinjuju v.2.9
This page goes over some recommended tools and approaches to troubleshooting the charm.
Before anything, always run juju status to check the list of charm statuses and the recommended fixes. This alone may already solve your issue.
Otherwise, this reference goes over how to troubleshoot this charm via:
juju logs
Please be familiar with Juju logs concepts and learn how to manage Juju logs.
Always check the Juju logs before troubleshooting further:
juju debug-log --replay --tail
Focus on ERRORS (normally there should be none):
juju debug-log --replay | grep -c ERROR
Consider enabling the DEBUG log level if you are troubleshooting unusual charm behaviour:
juju model-config 'logging-config=<root>=INFO;unit=DEBUG'
The Patroni/PostgreSQL logs are located inside SNAP:
> ls -la /var/snap/charmed-postgresql/common/var/log/*
/var/snap/charmed-postgresql/common/var/log/patroni:
-rw-r--r-- 1 snap_daemon snap_daemon 292519 Sep 15 21:47 patroni.log
/var/snap/charmed-postgresql/common/var/log/pgbackrest:
-rw-r----- 1 snap_daemon snap_daemon 7337 Sep 15 21:46 all-server.log
-rw-r----- 1 snap_daemon snap_daemon 5858 Sep 15 10:41 testbet.postgresql-stanza-create.log
/var/snap/charmed-postgresql/common/var/log/pgbouncer:
# The pgBouncer should be stopped on Charmed PostgreSQL deployments and produce no logs.
snap-based charm
First, check the operator architecture to become familiar with snap content, operator building blocks, and running Juju units.
To enter the unit, use:
juju ssh postgresql/0 bash
Make sure the charmed-postgresql snap is installed and functional:
ubuntu@juju-fd7874-0:~$ sudo snap list charmed-postgresql
Name Version Rev Tracking Publisher Notes
charmed-postgresql 14.9 70 latest/stable dataplatformbot held
From here you can make sure all snap (systemd) services are running:
ubuntu@juju-fd7874-0# sudo snap services
Service Startup Current Notes
charmed-postgresql.patroni enabled active -
charmed-postgresql.pgbackrest-service enabled active -
charmed-postgresql.prometheus-postgres-exporter enabled active -
ubuntu@juju-fd7874-0:~$ systemctl --failed
0 loaded units listed.
ubuntu@juju-fd7874-0:~$ ps auxww
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.4 0.0 167364 12716 ? Ss 21:40 0:02 /sbin/init
root 59 0.0 0.0 64596 20828 ? Ss 21:40 0:00 /lib/systemd/systemd-journald
root 112 0.0 0.0 11088 5740 ? Ss 21:40 0:00 /lib/systemd/systemd-udevd
root 115 0.3 0.0 4832 1816 ? Ss 21:40 0:01 snapfuse /var/lib/snapd/snaps/core22_864.snap /snap/core22/864 -o ro,nodev,allow_other,suid
root 116 0.2 0.0 4896 1880 ? Ss 21:40 0:01 snapfuse /var/lib/snapd/snaps/charmed-postgresql_70.snap /snap/charmed-postgresql/70 -o ro,nodev,allow_other,suid
root 117 0.0 0.0 4748 1644 ? Ss 21:40 0:00 snapfuse /var/lib/snapd/snaps/core20_2015.snap /snap/core20/2015 -o ro,nodev,allow_other,suid
root 119 0.0 0.0 4692 1600 ? Ss 21:40 0:00 snapfuse /var/lib/snapd/snaps/lxd_24322.snap /snap/lxd/24322 -o ro,nodev,allow_other,suid
root 120 0.6 0.0 4768 1840 ? Ss 21:40 0:04 snapfuse /var/lib/snapd/snaps/snapd_19993.snap /snap/snapd/19993 -o ro,nodev,allow_other,suid
systemd+ 225 0.0 0.0 16116 8100 ? Ss 21:40 0:00 /lib/systemd/systemd-networkd
systemd+ 227 0.0 0.0 25528 12664 ? Ss 21:40 0:00 /lib/systemd/systemd-resolved
root 241 0.0 0.0 7284 2792 ? Ss 21:40 0:00 /usr/sbin/cron -f -P
message+ 243 0.0 0.0 8668 4916 ? Ss 21:40 0:00 @dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
root 247 0.0 0.0 33084 18792 ? Ss 21:40 0:00 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
syslog 248 0.0 0.0 152764 4748 ? Ssl 21:40 0:00 /usr/sbin/rsyslogd -n -iNONE
snap_da+ 250 0.0 0.0 1303900 10216 ? Ssl 21:40 0:00 /snap/charmed-postgresql/70/usr/bin/prometheus-postgres-exporter
root 254 0.0 0.0 15312 7456 ? Ss 21:40 0:00 /lib/systemd/systemd-logind
root 281 0.0 0.0 7760 3508 ? Ss 21:40 0:00 bash /etc/systemd/system/jujud-machine-0-exec-start.sh
root 294 0.0 0.0 6216 1064 pts/0 Ss+ 21:40 0:00 /sbin/agetty -o -p -- \u --noclear --keep-baud console 115200,38400,9600 vt220
root 296 0.0 0.0 15420 9240 ? Ss 21:40 0:00 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
root 301 2.2 0.2 895540 97552 ? Sl 21:40 0:13 /var/lib/juju/tools/machine-0/jujud machine --data-dir /var/lib/juju --machine-id 0 --debug
root 335 0.0 0.0 110084 21336 ? Ssl 21:40 0:00 /usr/bin/python3 /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
root 418 0.0 0.0 235452 8128 ? Ssl 21:40 0:00 /usr/libexec/polkitd --no-debug
root 772 0.4 0.0 4764 1780 ? Ss 21:40 0:02 snapfuse /var/lib/snapd/snaps/snapd_20092.snap /snap/snapd/20092 -o ro,nodev,allow_other,suid
root 850 0.2 0.1 2058980 33536 ? Ssl 21:40 0:01 /usr/lib/snapd/snapd
root 1587 0.0 0.0 4780 3264 ? Ss 21:40 0:00 /bin/bash /snap/charmed-postgresql/70/start-patroni.sh
snap_da+ 1615 1.1 0.1 490500 39308 ? Sl 21:40 0:06 python3 /snap/charmed-postgresql/70/usr/bin/patroni /var/snap/charmed-postgresql/70/etc/patroni/patroni.yaml
snap_da+ 2582 0.0 0.0 215816 30076 ? S 21:41 0:00 /snap/charmed-postgresql/current/usr/lib/postgresql/14/bin/postgres -D /var/snap/charmed-postgresql/common/var/lib/postgresql --config-file=/var/snap/charmed-postgresql/common/var/lib/postgresql/postgresql.conf --listen_addresses=10.47.228.200 --port=5432 --cluster_name=postgresql --wal_level=logical --hot_standby=on --max_connections=100 --max_wal_senders=10 --max_prepared_transactions=0 --max_locks_per_transaction=64 --track_commit_timestamp=off --max_replication_slots=10 --max_worker_processes=8 --wal_log_hints=on
snap_da+ 2808 0.0 0.0 215816 10704 ? Ss 21:41 0:00 postgres: postgresql: checkpointer
snap_da+ 2810 0.0 0.0 215816 10496 ? Ss 21:41 0:00 postgres: postgresql: background writer
snap_da+ 2811 0.0 0.0 70540 8804 ? Ss 21:41 0:00 postgres: postgresql: stats collector
snap_da+ 2840 0.0 0.0 217980 21184 ? Ss 21:41 0:00 postgres: postgresql: operator postgres 10.47.228.200(36138) idle
snap_da+ 2947 0.0 0.0 216716 14736 ? Ss 21:41 0:00 postgres: postgresql: walsender replication 10.47.228.241(45254) streaming 0/A002FA8
snap_da+ 2952 0.0 0.0 215816 13140 ? Ss 21:41 0:00 postgres: postgresql: walwriter
snap_da+ 2953 0.0 0.0 216424 10848 ? Ss 21:41 0:00 postgres: postgresql: autovacuum launcher
snap_da+ 2954 0.0 0.0 215816 9132 ? Ss 21:41 0:00 postgres: postgresql: archiver last was 00000001000000000000000A.partial
snap_da+ 2955 0.0 0.0 216260 9516 ? Ss 21:41 0:00 postgres: postgresql: logical replication launcher
snap_da+ 6556 0.0 0.0 216780 14780 ? Ss 21:42 0:00 postgres: postgresql: walsender replication 10.47.228.164(48482) streaming 0/A002FA8
root 6799 0.0 0.0 39900 31164 ? S 21:42 0:00 /usr/bin/python3 src/cluster_topology_observer.py https://10.47.228.200:8008 /var/snap/charmed-postgresql/current/etc/patroni/ca.pem /usr/bin/juju-run postgresql/0 /var/lib/juju/agents/unit-postgresql-0/charm
root 9831 0.0 0.0 4780 3204 ? Ss 21:46 0:00 /bin/bash /snap/charmed-postgresql/70/start-pgbackrest.sh
snap_da+ 9859 0.0 0.0 56152 13584 ? S 21:46 0:00 /snap/charmed-postgresql/70/usr/bin/pgbackrest server --config=/var/snap/charmed-postgresql/70/etc/pgbackrest/pgbackrest.conf
root 10168 0.0 0.0 16908 10836 ? Ss 21:47 0:00 sshd: ubuntu [priv]
ubuntu 10171 0.0 0.0 17056 9628 ? Ss 21:47 0:00 /lib/systemd/systemd --user
ubuntu 10172 0.0 0.0 170148 4728 ? S 21:47 0:00 (sd-pam)
ubuntu 10234 0.0 0.0 17208 7944 ? R 21:47 0:00 sshd: ubuntu@pts/1
The list of running snap/systemd services will depend on configured (enabled) COS integration and/or backup functionality. The snap service charmed-postgresql.patroni must always be active and currently running (the Linux processes snapd, patroni and postgres).
To access PostgreSQL, check the charm users concept and request operator credentials to use psql:
> juju show-unit postgresql/0 | awk '/private-address:/{print $2;exit}'
10.47.228.200
> juju run postgresql/leader get-password username=operator
password: rV0Xn4l65KtQsHSq
> > psql -h 10.47.228.200 -U operator -d postgres -W
> > Password for user operator: rV0Xn4l65KtQsHSq
> > postgres=# \l
> > postgres | operator | UTF8 | C.UTF-8 | C.UTF-8 | operator=CTc/operator +
> > | | | | | backup=CTc/operator +
Continue troubleshooting your database/SQL related issues from here.
Warning: Do NOT manage users, credentials, databases, schema directly. This avoids a split brain situation with the operator and integrated applications.
It is NOT recommended to restart services directly as it might create a split brain situation with operator internal state. If you see the problem with a unit, consider removing the failing unit and adding a new unit to recover the cluster state.
As a last resort, contact us if you cannot determine the source of your issue.
Also, feel free to improve this document!
Install extra software
We recommend you do not install any additional software. This may affect stability and produce anomalies that are hard to troubleshoot.
Sometimes, however, it is necessary to install some extra troubleshooting software.
Use the common approach:
ubuntu@juju-fd7874-0:~$ sudo apt update && sudo apt install gdb
Setting up gdb (12.1-0ubuntu1~22.04) ...
Always remove manually installed components at the end of troubleshooting. Keep the house clean!
